Overview of user interface component properties
Below, you can find the properties of each of the user interface components, as well as the additional optional property groups that can be added to components.
Extra grid properties
When one of the below-mentioned controls is placed inside a grid, it will have four extra grid properties:
Property | Description |
Row | The 0-based number of the row in which the control is located. |
RowSpan | The number of rows over which the control spans. |
Column | The 0-based number of the column in which the control is located. |
ColumnSpan | The number of columns over which the control spans. |
Properties per component
Border
None
See also: Extra grid properties
Label
Name | The text of the label. |
TextAlignment | The alignment of the text: Left, Right, Center, or Justify. |
TextWrapping | Whether or not text will wrap when it reaches the edge of the label box: - Wrap: Text will always wrap when it reaches the edge of the label box. - WrapWithOverflow: Text will always wrap when it reaches the edge of the label box, except in case of long words. - NoWrap: No line wrapping is performed. |
TextTrimming | The way in which text is trimmed when it overflows the edge of the label box. - None: Text is not trimmed. - CharacterEllipsis: Text is trimmed after a character. An ellipsis (”...”) will replace the remaining text. - WordEllipsis: Text is trimmed after a word. An ellipsis (”...”) will replace the remaining text. |
FontFamily | The text font. |
FontSize | The text font size (in points). |
FontWeight | The font weight: Normal, Bold, or Light |
FontStyle | The font style: Normal, Italic, or Oblique |
Foreground | The text color. |
Grid
Rows | The number of rows in the grid. |
Height | The height of the row. The number of Height properties is equal to the number of rows specified in the Rows property. |
Columns | The number of columns in the grid. |
Width | The width of the column. The number of Width properties is equal to the number of columns specified in the Columns property. |
TabControl
Consists of TabPage components. These have one customizable property, the tab page name, which can have multiple lines. To enter a new line while customizing the tab page name, simply press Enter.
TogglePanel
Enable label | The text displayed on the panel when it is disabled. |
Disable label | The text displayed on the panel when it is enabled. |
ExpandingPanel
Name | The name of the expanding panel. |
ExpandDirection | The direction in which the panel will expand/collapse: Down, Up, Left, or Right. |
I/O
Description | The text displayed in the input/output box. |
Input | The matrix input linked with this box. Choose -1 to turn the input into the “park input”, i.e. the input to which an output will automatically be connected when it is disconnected from its earlier input. |
Include port number in description | Determines whether the port number is included in the description or not (e.g. “input 5” or “output 3”). |
Output | The matrix output linked with this box. |
To display extra information on IO buttons, based on other columns in the IO tables, use a placeholder {p:pid} in the button description, where “pid” is the parameter ID. For example: “This is input {p:1001}”.
Action
Label | The text displayed on the button. |
Type | The action that will be executed when the button is clicked: Connect, Disconnect, Lock/Unlock, or Undo. You can also select a “Custom” type (using the Customize option), for which the actions are specified in the Options box. |
Options | For Custom type actions, add one action per line in this box, using the same syntax as when using an Execute shape data field in Visio. See Overview of DataMiner shape data fields. |
The Undo action allows you to undo the latest connect or disconnect action. As the option can only be applied to undo one action, after Undo is clicked, the button is disabled until another action has been done. Optionally, you can select the Display confirmation option for the Undo action type, so a confirmation window is displayed whenever the button is used.
InfoPanel
Type | The type of information panel: Selected Input, Selected Output, Routed Outputs. |
Options | If Type is “Routed Outputs”, then in the Options property you can specify the connections that you do not want users to see. Example: One of the inputs is not connected to a real video source. Instead, it has a terminator pin attached to it, and shows a black screen. If an output is connected to this input, it is in fact not in use (i.e. blacked out). Although it is a matrix crosspoint, it does not represent a routed video signal and should therefore not be displayed. Syntax: Inputs and outputs must be specified with their numeric index, and can be separated by either commas or semicolons. - ignore-input:1,2,3 - ignore-output:11,12,13 |
Timer
Duration | The number of hours, minutes and seconds from which to count down. Default: 00:01:00 |
Visio
Link to view | The name of a DataMiner view that contains the Visio drawing. |
Optional property groups
To each of the components mentioned above, additional property groups can be added by means of the Add button in the lower left corner of the properties pane. These property groups can also be removed again, by clicking the x in the top-right corner of the optional block of properties.
The following optional property groups are available:
Font options
Property Description FontFamily The text font. FontSize The text font size (in points). FontWeight The font weight: Normal, Bold, or Light FontStyle The font style: Normal, Italic, or Oblique Foreground The text color. Note
The Font property group is by default available for the Label component.
Layout options
Property Description Height The height of the component. MinHeight The minimum height of the component. MaxHeight The maximum height of the component. This overrides the Height property. Width The width of the component. MinWidth The minimum width of the component. MaxWidth The maximum width of the component. Margin The four margins of the component, separated by commas, in the following order: left, top, right, bottom. HorizontalAlignment The horizontal alignment, which can be Left, Center, Right or Stretch. VerticalAlignment The vertical alignment, which can be Left, Center, Right or Stretch. Custom options
