Router Control design mode
To enter or to exit the design mode of the Router Control module, click the large cogwheel icon in the top-right corner.
In design mode, there are three panes:
On the left, there is a list of building blocks that you can use to create a custom configuration.
In the middle, there is a design area (which initially contains the default Router Control configuration).
On the right, there is a hierarchical list of building blocks used in the current configuration.
Any item that is clicked in the design area is automatically also selected in the list on the right.
In the lower right corner, the properties of a selected item can be configured.
Buttons
In the top-right corner of the card, you can find the following buttons:
Icon | Name | Description |
Backup | Save the current configuration to a compressed XML file on the client machine. |
Restore | Load a configuration that is stored in a compressed XML file on the client machine. To select the configuration, hover over this button and click the downward triangle next to it. |
Revert | Undo all changes and reload the configuration from the DMS. |
Save | Upload the current configuration to the DMS. |
Apply | Preview the changes you have made. |
