Assigning trend templates
You can either assign a trend template to an item with the Surveyor right-click menu, or in the Protocols & Templates module.
In the Surveyor:
Right-click the item to which you want to assign a trend template and click Edit.
In the Edit tab, go to Device Details.
Select the trend template in the Trend Template selection box.
Click Apply.
From DataMiner 9.0.5 onwards, to quickly access the Protocols & Templates module from the Surveyor, right-click an element or enhanced service, and select Protocols & Templates. This opens a submenu where you can open the current template, assign a different template or view all available templates.
In the Protocols & Templates module:
Select the protocol and protocol version
In the Trend section, select the trend template.
Right-click in the Elements section and select Assign Template. Alternatively, from DataMiner 9.0.5 onwards, you can also click the Assign elements button at the top of this section.
In the Assign template window, use the Add >> and << Remove buttons to assign the template to particular items.
All items in the column on the right have been assigned this trend template.
- Right-click an item in the Protocols & Templates module and select Remove to quickly remove a trend template from an item.
- Assigning templates is also possible via the elements tab of the Protocols & Templates module. See Working with the elements tab.
