Hiltron HCS4 - PSA Power Supply
This connector is used by DVEs (Dynamic Virtual Elements) created by the parent connector Hiltron HCS4.
This connector can be used to monitor a power supply module contained in a Hiltron HCS4 controller.
About
Product Info
Range Supported Firmware
1.0.0.x 0.10
System Info
Range DCF Integration Cassandra Compliant Linked Components Exported Components
1.0.0.x No Yes - -
How to use
This element using this connector is automatically generated by a parent element using the Hiltron HCS4 connector. It displays information about a power supply module managed by the Hiltron HCS4 unit controller.
