Adding a DataMiner Agent to a cluster running STaaS
  1. Verify the prerequisites listed under Adding a regular DataMiner Agent.
  2. Install the DataMiner Cloud Pack on the new DataMiner Agent.
  3. Stop DataMiner and CloudGateway on the new DMA.
  4. From a node in the cluster where CloudGateway is running, copy the folder C:\ProgramData\Skyline Communications\DataMiner CloudGateway\Data\CcaGatewayPersisted and place it in the same location on the new DMA.
  5. Remove the following files from the folder you just copied to the new DMA:
    • DmsAccessToken.data
    • DmsAccessTokenExpiration.data
    • DmsRefreshToken.data
    • DmsRefreshTokenExpiration.data
  6. Remove the NodeId.txt file from the folder C:\ProgramData\Skyline Communications\DxMs Shared\Data on the new DMA.
  7. Start CloudGateway on the new DMA.
  8. Configure DB.xml to use STaaS:
    1. In the C:\Skyline DataMiner folder, open DB.xml.
    2. Configure the Database tag with type="CloudStorage" as illustrated below:
      • For setups without proxy, use the following configuration:
        <?xml version="1.0"?>
        <DataBases xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns="http://www.skyline.be/config/db">
            <DataBase active="true" local="true" search="true" cloud="true" type="CloudStorage"/>
        </DataBases>
      • For setups with proxy (this requires DataMiner 10.4.5/10.5.0 or higher), use the following configuration, filling in the fields as required:
            <DataBase active="true" local="true" search="true" cloud="true" type="CloudStorage">
               <Proxy>
                  <Address>[Enter Address Here]</Address>
                  <Port>[Enter Port Here]</Port>
                  <UserName>[Enter UserName Here]</UserName>
                  <Password>[Enter Password Here]</Password>
               </Proxy>
            </DataBase>
        </DataBases>
  9. Start DataMiner on the new DMA.
  10. Join the DMA to the cluster using the steps described under Adding a regular DataMiner Agent or Failover configuration in Cube for a Failover Agent.
    The DMA should now be connected to the cluster running STaaS.
  11. Optionally, if the new DMA is not intended to host the CloudGateway DxM, you can safely uninstall it.
    In this case, the Admin app will still display connection information indicating that CloudGateway is not running. To remove this invalid state, contact DataMiner Support.
