Adding a DataMiner Probe as a node in a cluster
Verify the prerequisites listed under Adding a node to a DataMiner cluster.
Procedure
To add a DataMiner Probe to a cluster, follow the same procedure as when you add a regular DataMiner Agent, with one difference:
  • In the Add DataMiner Agent pop-up window, select the checkbox Add as an external DataMiner Agent.
Note that given the special nature of DMPs, there are differences compared to regular DataMiner Agents:
  • DMPs are only displayed in the manage tab of the Agents page. There it is possible to modify the settings or change the state of a DMP, like for any other Agent.
  • If you click the client communication indicator in the top right corner of the Cube interface, DMPs are not displayed in the list of DMAs in the system.
  • The client manages the connection to the DMP. If the connection cannot be set initially, you can try to reconnect until a stable connection has been made.
