Creating a hybrid cluster starting from a self-managed cluster
  • A cluster consisting of one or more self-managed DataMiner nodes using Storage as a Service.
  • A user account with the Admin or Owner role in the dataminer.services organization that owns the DaaS nodes.
Step-by-step procedure
  1. Make sure your self-managed nodes are upgraded to a supported DaaS DataMiner version.
    In general, all Feature Release versions starting from 10.5.11 and Main Release versions starting from 10.6.0 [CU7] are supported. For more details on supported versions, contact daas@dataminer.services.
  2. Make sure Swarming is enabled in the self-managed cluster.
  3. Make sure BrokerGateway is used in the self-managed cluster.
  4. In DataMiner, create a new user account HybridAdmin and configure it as follows:
    • Assign it to the built-in Administrators group.
    • Make sure Password never expires is selected.
    • Make sure the password meets the complexity requirements of DaaS nodes:
      • It does not contain the user's account name or parts of the user's full name that exceed two consecutive characters
      • It is at least six characters in length
      • It contains characters from three of the following four categories:
        • English uppercase characters (A through Z)
        • English lowercase characters (a through z)
        • Base 10 digits (0 through 9)
        • Non-alphabetic characters (for example, !, $, #, %)
    The HybridAdmin user account will be used for cluster syncing, which means it needs to have the same password on all Agents in the cluster.
  5. Contact daas@dataminer.services with a request to complete the setup.
    Make sure your email includes the following information:
    • The desired Azure region for the DaaS nodes.
      Make sure to choose a region close to where your self-managed nodes are deployed to minimize latency.
    • The time zone of the on-premises cluster
      It is important that the time zone of your DaaS nodes is aligned with that of your self-managed nodes. A mismatch can result in incorrect syncing and data loss when the cluster is created.
    • The organization name where your DataMiner System resides on https://dataminer.services.
    • The system name of your DataMiner System on https://dataminer.services.
    • The email address of an owner or admin in the provided organization who should become the owner of the new DaaS system.
    • The IP address of the DMA.
    • The password of the HybridAdmin user account.
    Skyline's DaaS team will perform the following steps to complete the setup:
    1. Deploy the DaaS nodes.
    2. Establish a VPN connection (see About the site-to-site VPN connection).
    3. Join the DaaS nodes to your self-managed cluster.
  6. Once the setup is fully functional, to improve security, either remove the HybridAdmin user account or change its password.
