Configuring the Cassandra database per DMA settings
If a DataMiner Agent in a cluster is offline, database configuration changes will not be applied to that DataMiner Agent. From DataMiner 10.3.6/10.4.0 onwards, you will get a warning on the Database page in System Center to make you aware of this. However, this warning will not be triggered for the offline Agent in a Failover setup.
If you choose not to use the recommended Storage as a Service (STaaS) setup but instead choose self-managed storage with a separate Cassandra cluster per DMA, configure the settings as follows:
  1. Go to Apps > System Center > Database.
  2. In the column on the left, select the Agent of which you want to configure the general database.
  3. Specify the following database settings, depending on your DataMiner version:
    • Type: Database per Agent.
    • Database: The type of database, i.e., Cassandra.
    • Name: The name of the database.
    • DB Server: The name or IP address of the server that hosts the database. There is no need to specify a port. Specifying a custom port is not supported, and the default port 9042 will be used whether you specify it or not (see Configuring the IP network ports).
    • Connection string: Can be filled in instead of the other fields, in which case this string will be used to connect to the database.
    • User: The username with which the DMA has to log on to Cassandra.
    • Password: The password with which the DMA has to log on to Cassandra.
  4. Click Save.
    Database configuration changes will not take effect until the Agent is restarted.
In the DB.xml file, you can specify the configuration data for several databases as well.
