What happens if one of the DMAs is restarted in a Failover setup?
If the offline DMA is restarted:
  • In the Alarm Console of the online DMA, a “Failing Heartbeat Path” notice will appear during the restart.
If the online DMA is restarted:
  • If the offline DMA detects several failing heartbeats because the restart takes a long time, an automatic switchover will occur.
    This depends on the duration of the restart and on the heartbeat settings.
    For more information on the heartbeat settings, see Heartbeats.
  • After the restart, if the online DMA cannot connect to the other DMA, it will go back online automatically.
