What happens if one of the DMAs is stopped in a Failover setup?
If the online DMA is stopped:
  • The other, offline DMA will detect heartbeat path failures and will go online.
  • In the Alarm Console of the other DMA a notice will appear, indicating that heartbeat paths and sync connection are failing.
  • In the Status dialog box, you will see that the DMA is Unreachable, and that Heartbeat and DB Sync are Failing.
If the offline DMA is stopped:
  • The online DMA will keep working as normal.
  • In the Alarm Console of the online DMA a notice will appear, indicating that heartbeat paths and sync connection are failing.
  • In the Status dialog box, you will see that the offline DMA is Unreachable, and that Heartbeat and DB Sync are Failing.
This is also what happens when a DMA shuts down unexpectedly, for instance because of a power failure.
