User interaction
This action allows the configuration of a dialog box asking for a user response.
This dialog box is a pop-up window consisting of different parts, with a default margin of 5 pixels.
To configure the dialog box, select parts in the Add part box on the right, and view the result in the preview on the left:
  • To enter a fixed piece of text:
    1. Choose Text.
    2. Type or paste the text in the Text field.
  • To display the contents of a variable in the dialog box:
    1. Choose Variable contents.
    2. Click the underlined section to select the variable.
  • To create a text box that the user will have to enter a value into:
    1. Choose Text box.
    2. Click the underlined section to select a destination variable.
  • To add a dropdown list:
    1. Choose Drop-down.
    3. Add the various options for the dropdown list with the Add new option button.
  • To display a button:
    1. Choose Button.
    2. Enter the text that should be displayed on the button.
    3. Choose a destination variable for the button.
  • To change the order of the parts, use the up and down buttons to the right of the parts.
  • To delete a part, click the x next to the part in question.
It is also possible to add dialog boxes in C# code blocks. For more information, see Building interactive automation scripts with C#.
