Running automation scripts
Once a script has been designed, it can be executed in several ways:
From DataMiner 10.3.0 [CU13]/10.4.0 [CU1]/10.4.4 onwards, to execute an automation script, you need the user permission Modules > Automation > Execute. Prior to DataMiner 10.3.0 [CU13]/10.4.0 [CU1]/10.4.4, to execute an automation script, you need the user permissions Modules > Automation > Execute and Modules > Automation > UI Available.
