Using Spectrum Analysis presets
About presets
Spectrum Analysis presets can be used to reload settings, to reload a set of markers, to save and reload a trace image, to load a reference trace, etc. The following information can be stored in a preset:
Settings, e.g., start frequency, stop frequency
Display settings, including the trace visibility
A reference trace
Marker positions
Reference lines
Threshold information
Measurement cycles
The ID of the measurement point for which the trace is measured
Presets can be saved publicly (i.e., shared) or privately:
Public: Anybody can access, use and modify these presets. Commonly used presets will typically be saved as “public” so that everybody performs the same measurement with the same settings, and store a reference trace image.
Private: Private presets are only available for the user account that created them. Other users will not be able to see or use these presets.
From DataMiner 10.5.0 [CU19]/10.6.0 [CU7]/10.6.10 onwards, when a spectrum analyzer is configured to use shared session mode, its latest configuration is automatically saved in a shared last session preset when a user closes the card. When another user opens the spectrum analyzer, this preset is loaded automatically, so all users see the same configuration. From DataMiner 10.5.0 [CU21]/10.6.0 [CU9]/10.6.12 onwards, other users can also be notified of changes to the shared last-session preset. See Sharing spectrum sessions for information on how to push these changes and how other clients can handle them.
Saving presets
In order to save a configuration, a preset must already exist that you can save the configuration into.
To save a preset in DataMiner Cube:
Go to the SAVE section of the Presets tab in the settings pane.
In the dropdown list, select the preset you want to save the configuration into.
Click Save.
Loading presets
To load a preset in DataMiner Cube:
Go to the LOAD section of the Presets tab in the settings pane.
To show public presets as well as private presets, select Show shared presets.
In the list of available presets, select the one you wish to load.
If the selected preset has a description, this will be displayed below the list of presets.
In the Preset contents section, select the checkboxes corresponding to the preset content you want to load.
- Prior to DataMiner 10.5.0 [CU21]/10.6.0 [CU9]/10.6.12, some checkboxes may not be available, depending on the selected preset. From DataMiner 10.5.0 [CU21]/10.6.0 [CU9]/10.6.12 onwards, all preset content checkboxes remain enabled. Bold labels indicate which content is available in the selected preset.
- Selecting or loading a private or public preset does not change your checkbox selections. Your selections are saved and restored when you reopen the Spectrum Analyzer. Last-session presets restore the session independently of the checkboxes used to load private and public presets.
Click the Load button.
When a reference trace has been loaded from a preset, it will be added in the list of traces in the info pane, with the corresponding trace color.
- You can change the reference trace color in the trace tab of the ribbon, by clicking Color > Reference trace, and selecting the new color.
- To hide the reference trace, in the trace tab of the ribbon, clear the selection from Show reference.
- From DataMiner 10.5.0 [CU18]/10.6.0 [CU6]/10.6.9 onwards, reference trace markers are also restored when a preset containing a reference trace is loaded.
Creating new presets
To create a new preset in DataMiner Cube:
In the settings pane, at the bottom of the Presets tab, click the Manage button.
Click the New button.
Enter a name for the preset and, optionally, a description.
Optionally, to create a public preset, select Share preset with other users. If you do not do so, the preset will by default be considered a private preset.
Optionally, make the preset protected by selecting Save as protected. Protected presets can only be edited by the user who made them or by users with the user permission Edit/Delete Protected Presets.
Click OK.
The preset will be added to the list of available presets.
Editing presets
For more information on how to save different information in a preset, see Saving presets.
To edit the settings, name or description for a preset:
Click the Edit button.
Edit the name, description and settings as needed, in the same way as when creating the preset.
Click OK.
Shared presets can be used in scripts, so modifications could cause a script to malfunction. Therefore, a warning will be shown when you attempt to modify a preset that is currently used by a script.
Deleting presets
To delete a preset in DataMiner Cube:
Click the preset you want to delete in order to select it.
Click the Delete button below the list of presets.
