HTTP(S) connections
For HTTP(S) connections, you can specify the following connection settings while creating or editing an element:
  • Site: The remote location. Set to <None> if a direct connection needs to be set up instead of a tunnel. This dropdown is only visible if the EdgeManager DxM is installed and remote locations are configured. For more information, refer to Edge Gateways.
  • IP address/host: The polling IP or URL of the destination.
  • IP port: The IP port of the destination. This is not always required. The default port for HTTPS communication is 443. If you specify a different port, also add the https:// prefix in the IP address field.
  • Bus address: The bus address of the device. This is not always required. If the proxy server has to be bypassed, specify bypassProxy.
  • Network: The network interface (NIC). If only one network interface is available on the DMA, it is automatically selected.
  • Skip SSL/TLS certificate verification (insecure): From DataMiner 10.4.12/10.5.0 onwards, SSL/TLS certificates are validated by default for all newly created HTTP elements. When this setting is enabled, SSL/TLS certificates will not be automatically validated.
    For HTTP elements created before the upgrade to 10.4.12/10.5.0, disable this option to enable automatic certificate verification.
    When the Skip SSL/TLS certificate verification (insecure) setting is enabled, in case an HTTP connector polls an HTTPS endpoint:
    • DataMiner will ignore invalid certificates in the following cases:
      • The server certificate is expired.
      • The server certificate is revoked.
      • The common name of the server certificate does not match the server name to which DataMiner is sending the request.
      • The certificate is issued by a Certificate Authority that is not trusted by the DataMiner Agent.
      • The server certificate is signed by a weak signature.
    • DataMiner will block communication when the server is offering a non-server certificate.
    • To skip SSL/TLS certificate validation for all elements that share the same protocol.xml file, set the SkipCertificateVerification element to true in the PortSettings element of the protocol.xml file.
    • To enable SSL/TLS certificate validation when using multithreaded HTTP communication, set requestSettings[6] to false when building the HTTP request in a QAction. For more information, see Setting up multithreaded HTTP communication in a QAction.
    • For backward compatibility, the SSL/TLS certificate validation is skipped by default for all elements created before version 10.5.0/10.4.12.
