Smart-serial connections
For smart-serial connections, you can specify the following connection settings while creating or editing an element:
Site: The remote location. Set to
<None>if a direct connection needs to be set up instead of a tunnel. This dropdown is only visible if the EdgeManager DxM is installed and remote locations are configured. For more information, refer to Edge Gateways. Note that a smart-serial element acting as a server is not supported in remote locations.IP address/host: The polling IP or URL of the destination.
In a Failover setup, instead of specifying the local IP address, use 127.0.0.1.
If you specify “any” as the host address, DataMiner listens on all IP addresses on the specified port.
Dynamic polling (available from DataMiner 10.3.11/10.4.0 onwards) is only supported when the smart-serial connection acts as a client. Assigning IP addresses like "127.0.0.1" or "any" makes the element act as a server, and it cannot switch to client mode without stopping first. Also, trying to assign a value like "127.0.0.1" to the dynamic IP parameter at runtime will cause an error.
IP port: The IP port of the destination. This is not always required.
Accepted IP address: Available if a smart-serial server port of type TCP is used. Allows you to specify one or more allowed IP addresses for the connection. The element will then only communicate with those IP addresses. This configuration makes it possible for several elements to listen on the same port but communicate exclusively with a different set of IPs.
To add another accepted IP address, below the box, click Add.
From DataMiner 10.6.12/10.7.0 onwards, if multiple elements listen on the same TCP server port and explicitly list the same client IP address, all of them receive data sent by that client. Only one element can respond to the client. Other elements that listen to the same server port but do not explicitly list the client's IP address do not receive its data. In earlier versions, only one of the elements received the data. This behavior is useful when multiple elements need to receive the same data without responding.
If AllowedIPAddresses.Disabled is set to "true" in the user settings of the smart-serial connection in the protocol, this functionality will not be available. See Specifying the allowed IP address.
Bus address: The bus address of the device. This is not always required.
Network: The network interface (NIC). If only one network interface is available on the DMA, it is automatically selected.
