TCP/IP and UDP/IP connections
For TCP/IP or UDP/IP connections, you can specify the following connection settings while creating or editing an element:
  • Site: The remote location. Set to <None> if a direct connection needs to be set up instead of a tunnel. This dropdown is only visible if the EdgeManager DxM is installed and remote locations are configured. For more information, refer to Edge Gateways. Note that a serial element acting as a server is not supported in remote locations.
  • IP address/host: The polling IP or URL of the destination.
    IPv6 destinations are not yet supported when SSL/TLS is enabled or when using UDP/IP. Use IPv4 destinations for these connection types.
  • IP port: The IP port of the destination. This is not always required.
  • Bus address: The bus address of the device. This is not always required.
  • Network: The network interface (NIC). If only one network interface is available on the DMA, it is automatically selected.
  • SSL/TLS: Select this checkbox to enable SSL/TLS encryption (for TCP/IP connections only).
    • TLS elements and non-TLS elements sharing the same TCP/IP port is not supported.
    • To use this feature for smart-serial elements acting as server, the system must be configured to support this encryption. See Enabling TLS encryption.
