WebSocket connections
For a WebSocket connection, you can specify the following connection settings while creating or editing an element:
Site: The remote location. Set to
<None>if a direct connection needs to be set up instead of a tunnel. This dropdown is only visible if the EdgeManager DxM is installed and remote locations are configured. For more information, refer to Edge Gateways.IP address/host: The polling IP or URL of the destination.
IP port: The IP port of the destination. This is not always required.
Bus address: The bus address of the device. This is not always required. If the proxy server has to be bypassed, specify bypassProxy.
Network: The network interface (NIC). If only one network interface is available on the DMA, it is automatically selected.
