Changing the alarm range for one parameter
Both from the Alarm Console and from a parameter card, it is possible to quickly change the alarm range for one particular parameter. This can be particularly useful for users who do not have access to the Protocols & Templates module.
There are several ways you can access the alarm range editor:
  • In the Alarm Console, right-click an alarm for that particular parameter, and select Change > Alarm range.
  • On a parameter card, click the hamburger button in the upper-left corner, and select Change alarm range.
  • On a parameter card, go to the templates tab and select ALARM.
In the alarm range editor, you can do the following:
  • Clear the Monitored checkbox to stop monitoring the parameter.
  • Change the type of alarm monitoring: Normal, Relative, Absolute, or Rate.
  • Enter different values for the alarm thresholds.
  • Select Info and enter a parameter value. Whenever the parameter gets this value, an information event will be generated.
At the bottom of the window, an information message will show you what other elements use the same alarm range.
To save your changes, there are two options:
  • To change the alarm range for all elements using the same template, click Update Alarm Template.
  • To only change the alarm range for this element, click Update this element only. In this case, a copy of the alarm template will be created, and you will have to enter a name for this new alarm template.
If a parameter is monitored by an alarm template group, the template shown in the alarm range editor is the alarm template with the highest priority monitoring that parameter.
