Configuring hysteresis in an alarm template
Two types of hysteresis are available, clear hysteresis and alarm hysteresis, respectively having an effect on the clearing and on the triggering of alarms.
For a visual example of how hysteresis can be configured in an alarm template, watch the following video. The configuration options are also explained in the text below.
Watch first: Creating an alarm template
  • Enter a value in the Hyst off column to determine the number of seconds before the severity level of an alarm decreases.
  • Enter a value in the Hyst on column to determine the number of seconds before the severity level of an alarm increases.
  • If you want to apply hysteresis to specific severity levels only, when you enter a value in the Hyst off or Hyst on box, select the severity levels in the dropdown list below the box.
  • For most parameters, the hysteresis interval has to be higher than the polling interval. For example, if a parameter is only polled every 10 seconds, you should not configure a hysteresis interval of 5 seconds. However, an exception to this are parameters updated via traps or via a smart-serial connection.
  • Using hysteresis in combination with conditions on the same parameter is not supported.
  • Using hysteresis in combination with history sets on the same parameter can cause unexpected behavior in alarm timestamps, as both features modify the parameter and alarm times. For this reason, we do not recommend combining them.
