Activating soft-launch options
For most soft-launch options, you will need the following file on your DataMiner server: C:\Skyline DataMiner\SoftLaunchOptions.xml. If this file is not present yet, you will need to create it. In this file, for each feature you want to activate, you can add a specific tag and set it to the value "true".
For example, this SoftLaunchOptions.xml configuration activates the "BookingSwarming" and "DataAPI" features:
<SLNet>
   <BookingSwarming>true</BookingSwarming>
   <DataAPI>true</DataAPI>
</SLNet>
  • All XML tags in SoftLaunchOptions.xml are case-sensitive.
  • All soft-launch flags (e.g., <BookingSwarming>) must be placed within the <SLNet> parent tag.
After you have modified this configuration file, you must restart your DataMiner Agent to activate the changes. If you have a cluster of DataMiner Agents, every DataMiner Agent in the cluster will need to be restarted. Many of the soft-launch options also require an IIS restart when they are activated.
For some Cube-only features, it is not necessary to configure a tag in SoftLaunchOptions.xml. For these features, it is sufficient to access DataMiner Cube using a specific argument. In DataMiner Cube, you can specify this argument in the start window by clicking the “…” button in the tile representing the DMS you want to connect to, and then specifying the argument in the Advanced section. For more information, see Arguments for DataMiner Cube.
For some features, a different configuration may be required. For more information, see Overview of soft-launch options.
When you create a DaaS system, some soft-launch options will be enabled by default. If you want to change which soft-launch options are enabled, contact daas@dataminer.services. To know which options are enabled by default, refer to the overview of soft-launch options.
