Overview of soft-launch options
The list below contains an overview of all available soft-launch options. Unless otherwise specified, the key must be added in SoftLaunchOptions.xml with the value "true" in order to activate the feature.
The list also details the minimum DataMiner version to start using each option and, in case the feature has already been officially released in a later DataMiner version, the "Release version" when it becomes available. From that "Release version" onwards, the feature is active by default and any soft-launch configuration for the feature is ignored. As such, it is not necessary to remove a tag from SoftLaunchOptions.xml when the corresponding feature is officially released.
AnomalyFeedback
Allows you to provide positive or negative feedback on anomaly suggestion events and alarms. This feedback is stored in the ai_anomalyfeedback table in the indexing database and is used to enhance anomaly event generation.
- Minimum version: 10.4.4
- Release version: 10.4.11
Applications
Enables the Low-Code Apps module.
Requires an IIS restart.
- Minimum version: 10.0.8
- Release version: 10.2.5/10.3.0 (RN 33040)
BookingData
Enables the BookingData Visual Overview component.
- Minimum version: 10.2.7
- Release version: 10.3.8/10.4.0 (RN 36489)
BookingSwarming
Makes it possible to swarm bookings.
- Minimum version: 10.5.1
- Release version: To be determined
BrokerGateway
Disables specific NATS logic, in order to use the BrokerGateway DxM for the NATS configuration instead.
- Minimum version: 10.4.1
- Release version: 10.5.5/10.5.0 [CU2]
See also: Migrating to BrokerGateway
ClusterEndpointsManager
Allows you to disable the ClusterEndpointsManager. This can prevent possible issues, but it will not be possible to migrate to BrokerGateway. If this option is not specified or if it is set to "true", ClusterEndpointsManager is enabled.
- Minimum version: 10.5.0 [CU5]/10.5.8
- Release version: 10.5.0 [CU5]/10.5.8
As the BrokerGateway migration must be done before you can upgrade to a DataMiner 10.6.x version, this option can only be used with 10.5.x DataMiner versions. Make sure this option is no longer present before you upgrade to DataMiner 10.6.x or higher, and do not add it in recent DataMiner versions. Prior to DataMiner 10.6.0 [CU9]/10.6.12, adding it can cause problems with your BrokerGateway setup. In later versions, it will do nothing.
CorrectedDisplayKeyOnNaming
Takes exception values into account for display key generation. See CorrectedDisplayKeyOnNaming soft-launch option
This option is enabled by default when DataMiner is deployed in the cloud (DaaS).
- Minimum version: 10.0.11/9.6.0 [CU18]/10.0.0 [CU6]
- Estimated release version: To be determined
CPEIntegration
Enables the Topology app in DataMiner Cube. Note that you also need specific protocol changes in order to benefit from this. See Topology app configuration.
- Minimum version: 9.6.7
- Release version: Cube 10.4.0 [CU14]/10.5.0 [CU2]/10.5.5
DataAPI
Enables Data API functionality and scripted connectors. This displays the Data Sources module in DataMiner Cube.
- Minimum version: 10.4.2/10.4.0
The latest version of the DataAggregator DxM and DataAPI DxM also have to be installed for this feature to work.
Diagnostics
Enable functionality to retrieve diagnostics from several DataMiner core processes. This is currently not used.
- Minimum version: 9.6.3
DirectViewRemoteDataUpdates
Updates the values of direct view tables.
DOMManager
Enables the use of DOM data in dashboards and applications.
- Minimum version: 10.1.7
- Release version: 10.3.6/10.4.0 (RN 36124)
DynamicUnits
Allows you to enable dynamic units in Data Display in DataMiner Cube. When enabled, many numerical values are automatically converted into more readable formats with appropriate units. For example, 11 939 964 kB is displayed as 11.9 GB.
The following units are automatically converted:
- Bytes: B, kB, MB, GB, TB, PB, EB, ZB, YB
- Kibibytes: KiB, MiB, GiB, TiB, PiB, EiB, ZiB, YiB
- Bits: b, kb, Mb, Gb, Tb, Pb, Eb, Zb, Yb
- Bits per second: bps, kbps, Mbps, Gbps, Tbps, Pbps, Ebps, Zbps, Ybps
- Bytes per second: Bps, kBps, MBps, GBps, TBps, PBps, ZBps, YBps
From DataMiner 10.4.0 [CU10]/10.5.0 [CU0]/10.5.1 onwards, this soft-launch feature is released and is enabled by default. To disable it, set this soft-launch option to false.
In versions prior to 10.4.0 [CU10]/10.5.0 [CU0]/10.5.1, this feature is disabled by default. If you want to test this feature for one DataMiner Cube session only, use the argument SOFTLAUNCH_DYNAMICUNITS=Enabled.
- Minimum version: 10.0.12
- Release version: 10.4.0 [CU10]/10.5.0 [CU0]/10.5.1 (RN 41436)
Functions
This option enabled the Virtual Functions module in Cube. The module and related objects are End of life and should no longer be used.
GenericInterface
Provides access to additional data sources and operators for GQI in the Dashboards app and Low-Code Apps.
Requires an IIS and DataMiner restart.
Some features that originally required this option are fully available in recent DataMiner versions:
- The DCF connections GQI data source (available from DataMiner 10.1.6 onwards).
- The "Sort" operator (available from DataMiner 10.2.11/10.3.0 onwards).
- The trend data patterns, trend data pattern events, and behavioral change events data sources (available from DataMiner 10.3.3/10.4.0 onwards).
- The object manager instances data source (available from DataMiner 10.3.6 onwards).
- The profile instances data source (available from DataMiner 10.3.0 CU11/10.4.2 onwards).
- Minimum version: 10.0.13
- Minimum version for the custom operator: 10.2.7
- Release version for the custom operator: 10.3.0 [CU10]/10.4.1 (RN 37840)
- Estimated release version for other data sources and operators: To be determined
LegacyAnnotations
Enables or disables the legacy Annotations module.
- Minimum version: 10.1.10/10.2.0
The legacy Annotations module is disabled by default as from DataMiner versions 10.4.0/10.4.1 (RN 37786). If you want to keep on using this legacy module, before upgrading or uploading a 10.4.x upgrade package, set this soft-launch option to true (see Activating SoftLaunch Options), then run C:\Skyline DataMiner\Tools\ConfigureIIS.bat as Administrator, and restart the DataMiner Agent. However, note that using Annotations is no longer possible from DataMiner 10.6.0/10.6.1 onwards.
When you disable this option, all existing annotations will be removed, and you will no longer be able to access them.
LegacyReportsAndDashboards
Enables or disables the legacy Reports and Dashboards modules.
The legacy Reports and Dashboards modules are disabled by default as from DataMiner versions 10.4.0/10.4.1 (RN 37786). If you want to keep on using these legacy modules, before upgrading or uploading a 10.4.x upgrade package, set this soft-launch option to true (see Activating SoftLaunch Options), then run C:\Skyline DataMiner\Tools\ConfigureIIS.bat as Administrator, and restart the DataMiner Agent.
ReportsAndDashboardsAutomationScript
Enables the automation script component in the Dashboards app, which is visualized as a button. This component can be used to execute scripts. It requires no data but can have elements or parameters as filters. If the ReportsAndDashboardsButton option is also enabled, one button component will be available that can be used with an automation script or with a button parameter.
- Minimum version: 9.6.8
Enables the parameter button component in the Dashboards app. This component requires button parameters as data and can be used to trigger button parameters.
If the ReportsAndDashboardsAutomationScript option is also enabled, the button acts as an automation script component instead unless a button parameter is added.
- Minimum version: 10.0.3
ReportsAndDashboardsButtonPanel
Enables the button panel component in the Dashboards app.
- Release version: 10.3.9/10.4.0 (RN 36775)
ReportsAndDashboardsDynamicVisuals
Enables the grid component in the Dashboards app.
- Minimum version: 10.2.12
- Release version: 10.3.0 [CU10]/10.4.1 (RN 37812)
ReportsAndDashboardsExport
Enables the export to PDF button within the Dashboards app itself. Creating PDFs of dashboards is possible outside the app (e.g., via DataMiner Scheduler) without this soft-launch option.
- Minimum version: 9.6.4
- Release version: 10.2.12/10.3.0 (RN 34634)
ReportsAndDashboardsGQIMaps
Enables a new Maps component in the Dashboards app and the Low-Code Apps.
- Minimum version: 10.3.2
- Release version: 10.5.4
ReportsAndDashboardsPTP
Enables the Query Filter component in the Dashboards app.
- Prior to DataMiner 10.0.13, this option also enables the Generic Interface feature in the Dashboards app, which becomes available from 10.0.13 onwards (partially using the GenericInterface soft-launch option).
- Prior to DataMiner 10.1.5, this option also enables the Node Edge component, which becomes available by default from DataMiner 10.1.5 onwards.
- Minimum version: 10.0.10
- Release version: 10.3.9/10.4.0 (RN 36822)
ReportsAndDashboardsScheduler
Enables the Timeline component in the Dashboards app.
ServiceProfilesMigration
Enables the service profiles export and import in the DataMiner Cube Services app. This is a Cube-only feature that can only be activated per session with the argument ENABLEFEATURE=ServiceProfilesMigration.
SLProtocolAsX64
Enables SLProtocol as a 64-bit process. This option is not configured in SoftLaunchOptions.xml. For more information on how to activate this, refer to Activating SLProtocol as a 64-bit process.
- Minimum version: 10.1.8
SLProtocolAsX86
Enables SLProtocol as a 32-bit process. This option is not configured in SoftLaunchOptions.xml. For more information on how to activate this, refer to Activating SLProtocol as a 32-bit process.
- Minimum version: 10.3.9
- Release version: N/A
SnmpPollingSnmpPlusPlusOnly
Configures the DataMiner System to use SNMP++ for the polling of all three SNMP versions, instead of only for SNMPv3.
From DataMiner 10.5.0 [CU20]/10.6.0 [CU8]/10.6.11 onwards, enabling this option also allows the use of empty set community strings in DataMiner element configuration and in the Credentials Library.
- Release version: To be determined.
- This feature does not support polling of IPv6 addresses. In case IPv6 addresses are polled on your DMA, do not activate this feature.
- NT_SNMP_RAW_GET, NT_SNMP_GET, NT_SNMP_RAW_SET and NT_SNMP_SET calls take this soft-launch option into account as from DataMiner versions 10.5.0/10.4.9. Prior to DataMiner versions 10.5.0/10.4.9, SNMPv1 and SNMPv2
RawGetandRawSetcalls are always executed using WinSNMP.
Swarming
Enables Swarming support for eligible systems.
- Minimum version: 10.3.11
- Release version: DataMiner 10.5.1/10.6.0
This soft-launch option is not supported in the Main Release track.
UseWebIAS
Uses an embedded web browser for automation script execution instead of the native Cube pop-up window.
- Minimum version: 10.1.4
UserDefinableAPI
Enables the Cube UI for User-Defined APIs.
- Minimum version: 10.3.5
- Release version: 10.3.6/10.4.0 (RN 36273)
