SLNet memory leak caused by ClusterEndpoint.json sync
Affected versions
  • Feature Release: DataMiner 10.5.7 [CU0] and 10.5.8
  • Main Release: DataMiner 10.5.0 [CU4] build 15943, 10.5.0 [CU5] build 16086
Cause
After an upgrade to one of the affected DataMiner versions, it is possible that C:\Skyline DataMiner\Configurations\ClusterEndpoint.json starts to sync incorrectly, resulting in a storm of updates, which in turn causes a memory leak in SLNet that causes Agents to disconnect. The severity of the issues scales with the size of the DataMiner System and the number of Failover pairs in the cluster.
Fix
Install DataMiner 10.5.0 [CU4] build 16239, DataMiner 10.5.0 [CU5] build 16243, DataMiner 10.5.0 [CU6], DataMiner 10.5.7 [CU1], DataMiner 10.5.8 [CU1], or DataMiner 10.5.9.
Workaround
In DataMiner 10.5.0 [CU5] (build 16086) or 10.5.8, you can prevent this issue by setting the ClusterEndpointsManager soft-launch option to "false" on each DataMiner Agent in the cluster. However, note that it is not possible to migrate to BrokerGateway while this option is disabled.
Description
After an upgrade to one of the affected DataMiner versions, a serious SLNet memory leak can occur, causing DataMiner Agents to disconnect frequently.
