Using isolation frameworks
The SLProtocol interface is heavily used in protocols as it acts as the interface between SLScripting (the process executing QActions) and SLProtocol (the process executing the protocol logic).
Therefore, it is very likely you will end up in a situation where you want to test a method that has a dependency on the SLProtocol interface. Below, you can learn how to fake SLProtocol so you can easily create unit tests that have a dependency on this interface.
Faking SLProtocol using MOQ
Consider, for example, the following method:
public string Rewrite(SLProtocol protocol, string path)
if(path == null)
throw new ArgumentNullException(nameof(path));
if(String.IsNullOrWhiteSpace(path))
throw new ArgumentException("Path is empty or white space.", nameof(path));
string[] pathParts = path.Split('\\');
string[] abbreviatedPath = new string[pathParts.Length];
for (int i = 0; i < pathParts.Length; i++)
string part = pathParts[i];
if (part == "Generic")
abbreviatedPath[i] = "SLCGeneric";
protocol.Log("QA" + protocol.QActionID + "|Rewrite|Path '" + path + "' must not contain 'Generic'. Auto-adjusting to 'SLCGeneric'.", LogType.Error, LogLevel.NoLogging);
continue;
if (itemsToAbbreviate.Contains(part))
abbreviatedPath[i] = Convert.ToString(part[0]);
else
abbreviatedPath[i] = part;
return String.Join(@"\", abbreviatedPath);
This method is very similar to the method shown in Creating unit tests. However, note that the method now has an additional parameter of type SLProtocol.
Suppose you now want to create a unit test for this method. When calling the Rewrite method in the Act step of your test method, you should pass along something that implements SLProtocol.
One option is to create your own class that implements the SLProtocol interface. However, an easier alternative is to make use of an isolation framework.
For this, you can for example use the Moq library. To start using the Moq library, select your test project in the Solution Explorer, right-click it, and then select Manage NuGet Packages. Click Browse and type "Moq". Select the package and click the Install button.
The best way to explain how this framework works is by using it through an example.
In the Arrange step, you create a new instance of Mock specifying SLProtocol for the type parameter (Note that you may need to add a reference to the SLManagedScripting DLL file in your test project first). Then in the Act step, you pass fakeSLProtocol.Object as the object that implements SLProtocol.
[TestMethod()]
public void Rewrite_PathWithItemsToAbbreviate_ReturnsAbbreviatedPath()
// Arrange
PathRewriter pathRewriter = new PathRewriter();
string path = @"Visios\Customers\Skyline\Protocols\Test";
string expected = @"V\C\Skyline\P\Test";
var fakeSlProtocol = new Mock<SLProtocol>();
// Act
string result = pathRewriter.Rewrite(fakeSlProtocol.Object, path);
// Assert
Assert.AreEqual(expected, result);
In this example, the object implementing the SLProtocol interface is used as a stub, i.e., it just acts as a replacement for the dependency we had. This is all it takes to create an SLProtocol fake.
In some tests, you may want to verify or assert something on the fake object (e.g., whether a specific method was called). Whenever this is the case, your fake is referred to as a mock.
For example, suppose you want to create an additional unit test to ensure that the Log method gets called whenever "Generic" is part of the specified path. This can be done as follows:
[TestMethod()]
public void AbbreviatePath_PathContainingGeneric_CallsLogMethod()
// Arrange
string path = @"Visios\Customers\Generic";
var slProtocolMock = new Mock<SLProtocol>();
// Act
pathRewriter.Rewrite(slProtocolMock.Object, path);
// Assert
slProtocolMock.Verify(p => p.Log(It.IsAny<string>(), It.IsAny<LogType>(), It.IsAny<LogLevel>()));
By calling the Verify method on the slProtocolMock object, you can verify whether the Log method has been called. In this case, the values that were provided when the Log method was invoked are not important (hence the use of It.IsAny<T>). However, it is possible to also verify the values if this is needed. The following example verifies the message:
[TestMethod()]
// Arrange
slProtocolMock.Setup(p => p.QActionID).Returns(10);
string expectedMessage = $"QA10|Rewrite|Path '{path}' must not contain 'Generic'. Auto-adjusting to 'SLCGeneric'.";
// Act
// Assert
slProtocolMock.Verify(p => p.Log(expectedMessage, It.IsAny<LogType>(), It.IsAny<LogLevel>()));
Note the use of the Setup method on the mock object. This allows you to specify what should be returned when the QActionID property is called.
The use of isolation frameworks like Moq allows you to easily create stubs and mocks. It allows you to perform advanced assertions on the mock objects such as verifying the number of times a method got invoked, etc.
Useful links
For more information on the Moq framework, see:
