General Feature Release 10.6.10 CU1
- For release notes related to DataMiner Cube, see DataMiner Cube Feature Release 10.6.10.
- For release notes related to the DataMiner web applications, see DataMiner web apps Feature Release 10.6.10.
- For information on how to upgrade DataMiner, see Upgrading a DataMiner Agent.
Before you upgrade to this DataMiner version:
Make sure version 14.44.35211.0 or higher of the Microsoft Visual C++ x86/x64 redistributables is installed. Otherwise, the upgrade will trigger an automatic reboot of the DMA in order to complete the installation.
The latest version of the redistributables can be downloaded from the Microsoft website:
Make sure all DataMiner Agents in the cluster have been migrated to the BrokerGateway-managed NATS solution.
For detailed information, see Migrating to BrokerGateway.
Important changes
The following changes may have an impact on your system, so please make sure to check these before you upgrade:
- DataMiner key vault [ID 44075] [ID 44349] [ID 44350] [ID 44351] [ID 44352] [ID 44353] [ID 44354] [ID 44701] [ID 44702] [ID 44911] [ID 46047] [ID 46061]
- Load, save, and delete actions for services have been rerouted from SLXml to the StorageModule DcM [ID 46134]
Changes
Fixes
DataMiner services could fail to load during DataMiner startup [ID 46773]
Since DataMiner Feature Release 10.6.10, in some cases, DataMiner services could fail to load during DataMiner startup.
