General Feature Release 10.6.2
Before you upgrade to this DataMiner version:
New features
Automation: New message to retrieve information about the available automation scripts [ID 44209]
A new GetAvailableAutomationScriptsRequestMessage now allows you to retrieve the following information about each automation script available in the DataMiner System:
  • The folder containing the script's XML file.
  • Whether or not the script supports a dedicated log file.
The above-mentioned message can only be used on systems with an Automation license by users who have the following permissions:
  • Modules > Automation > UI available
  • Modules > Automation > Execute
Changes
Enhancements
DataMiner upgrade: New upgrade action will register DataMiner exe files with Windows Error Reporting [ID 39440]
During a DataMiner upgrade, from now on, a new upgrade action will register all DataMiner SL*.exe and "DataMiner *.exe" files with Windows Error Reporting (WER). This will make sure that, each time a DataMiner process crashes for whatever reason, a full crash dump is created in C:\Skyline DataMiner\Logging\CrashDump\wer\<ExeName>. These WER crash dumps will allow Skyline to thoroughly investigate any issue that might occur.
  • Each time a crash dump is created for a particular process, any existing crash dumps for the same process will be automatically deleted. Per DataMiner process, only the most recent crash dump will be kept.
  • Although the entire C:\Skyline DataMiner\Logging\CrashDump\wer\ folder will be cleared during a DataMiner upgrade, DataMiner will not manage it. Removing crash dumps from this folder will not require a DataMiner restart.
  • Currently, WER crash dumps are not included in SLLogCollector packages, and CDMR is not aware of them.
Security enhancements [ID 43789]
OpenSearch: Enhanced health monitoring [ID 43951]
A number of enhancements have been made with regard to health monitoring of OpenSearch databases.
Also, all logging with regard to OpenSearch health monitoring can now be found in SLSearchHealth.txt. Up to now, that logging was added to SLCassandraHealth.txt.
Note that, from now on, if not all nodes of the OpenSearch cluster are listed in the Db.xml file, a notice will be generated to warn operators.
These enhancements have been reverted. See SLDataGateway issue caused by OpenSearch health monitoring [ID 44647].
Augmented Operations: Server-side support for new flatline detection modes [ID 44094]
When, in DataMiner client applications (e.g., DataMiner Cube), you are configuring the Augmented Operations alarm settings for a particular parameter in an alarm template, from now on, it will be possible to choose between the following flatline detection modes:
Mode Description
Smart flatline alarming In this mode, SLAnalytics will automatically determine when a flatline period is anomalous by comparing it to the parameter's historical behavior. A new flatline period will only trigger an alarm if it is significantly longer than previously observed flat periods.
Absolute flatline alarming In this mode, you can define a fixed duration threshold (in seconds) for when a flatline event should trigger an alarm. Additionally, you can assign a severity level to the generated flatline alarm event.
See also: Alarm templates: New flatline detection modes in Augmented Operations alarm settings [ID 44191]
dataminer.services: Restrictions when adding a DMA to a DMS [ID 44171]
From now on, when you try to add a DataMiner Agent to a DataMiner System, the operation will fail in the following cases:
  • The DataMiner Agent is cloud-connected, but the DataMiner System is not.
  • The DataMiner Agent and the DataMiner System are cloud-connected, but they do not have the same identity, i.e., they are not part of the same cloud-connected system.
If the DataMiner System is a STaaS system, adding a DataMiner Agent will also fail if the DataMiner Agent is not cloud-connected.
Elasticsearch/OpenSearch: Enhanced history alarm filtering on service ID or service name [ID 44192]
When, on a system with a Cassandra Cluster database, history alarms are filtered on service ID or service name, up to now, that filter would not be translated correctly to Elasticsearch or OpenSearch. From now on, that filter will be translated correctly. As a result, overall performance will increase when applying the filter in question to large datasets.
Also, filtering on alarm properties or interfaces using wildcards or regular expression has now been made case insensitive.
Scheduler will now be able to start more than 10 synchronously running automation scripts [ID 44200]
Up to now, using Scheduler, it would only be possible to start a maximum of 10 synchronously running automation scripts.
From now on, it will be possible to start more than 10 synchronously running automation scripts.
Enhanced performance when upgrading DxMs [ID 44210] [ID 44211]
Because of a number of enhancements, overall performance has increased when the following DxMs are upgraded during a DataMiner upgrade:
  • BrokerGateway
  • StorageModule
SLLogCollector packages will now also include time zone info, domain info, IP addresses of NICs, Web.config files, IIS configuration, and HTTP service state [ID 44223]
SLLogCollector packages will now also include the following information:
  • Time zone info, which will be stored in the following file:
    /Windows/powershell.exe Get-TimeZone_.txt
  • Windows domain info, which will be stored in the following files:
    /Windows/nltest.exe _dclist_.txt
    /Windows/nltest.exe _domain_trusts.txt
    /Windows/nltest.exe _dsgetdc_.txt
  • The IP addresses of all network adapters, which will be stored in the following files:
    /Network Information/NetworkInterface_GetAllNetworkInterfaces.txt
    /Network Information/powershell.exe [System.Net.Dns]_GetHostname().txt
  • All Web.config files found in C:\Skyline DataMiner\WebPages and all its subfolders.
  • The entire IIS configuration.
  • A snapshot of the HTTP service state (Request Queue View), which will be stored in the following file:
    /Network Information/netsh.exe http show servicestate view=requestq verbose=no.txt
Relational anomaly detection: GetRADParameterGroupInfoResponseMessage now also includes the ID of the RAD parameter group [ID 44237]
The response to a GetRADParameterGroupInfoMessage will now also include the ID of the RAD parameter group.
SLAnalytics: New database synchronization tasks will be paused when the queue is too long [ID 44243]
When database operations fail or take too long, the queue of database synchronization tasks (which update model information) can grow excessively, causing the SLAnalytics process to consume increasing amounts of memory.
From now on, SLAnalytics will pause the creation of new synchronization tasks for some types of model information whenever there are too many pending tasks already. New synchronization operations will only be created again once the backlog has decreased.
Service & Resource Management: Enhanced communication between resource managers across DataMiner Agents [ID 44279]
A number of enhancements have been done with regard to the communication between resource managers across DataMiner Agents. This will especially enhance performance when starting multiple bookings on non-master DMAs.
DataMiner upgrade: DataMiner Assistant DxM will now be included in the DataMiner web upgrade packages [ID 44291]
In order to upgrade the DataMiner Assistant DxM, up to now, you had to install a full DataMiner server upgrade package (main release or feature release).
From now on, the DataMiner Assistant DxM will be included in the DataMiner web upgrade packages instead.
See also: DataMiner upgrade: DataMiner Assistant DxM will now be included in the DataMiner web upgrade packages [ID 44291]
The DataMiner Assistant DxM will only be upgraded when an older version is found on the DataMiner Agent. If no older version is found, it will not be installed.
SLSNMPManager: Enhanced performance of the SNMP++ library [ID 44372]
Because of a number of enhancements, overall performance of the SNMP++ library has increased, especially when polling large SNMP tables.
Automation: Entrypoint ID added to the 'Finished executing script' log entry [ID 44382]
The entry added to the SLAutomation.txt log file when an automation script has finished will now contain the entrypoint ID.
In the following example, the entrypoint ID can be found at the end of the entry between brackets (11):
2025/12/18 13:40:00.546|SLAutomation.exe 8.0.1415.2|22300|16908|CAutomation::Execute|INF|0|Finished executing script: 'script_RT_USER_DEFINABLE_APIS_BodySizeLimit_RT_USER_DEFINABLE_APIS_BodySizeLimit_MaxResponseBodySize' (ID: 7) - SUCCEEDED - Execution took 00.308s. (11)
Fixes
Problem when a connector was deleted immediately after it had been uploaded [IID 44083]
When a connector was deleted immediately after it had been uploaded, in some rare cases, events triggered by the connector upload would still be adding references to the SLNet cache while the events triggered by the connector deletion were already trying to remove those references. This would lead to the SLNet cache incorrectly containing references to connectors that no longer existed on disk.
Not possible to export elements with logger tables on systems with Cassandra Cluster and OpenSearch [ID 44105]
On a system with Cassandra Cluster and OpenSearch, up to now, it would incorrectly not be possible to export elements with logger tables.
A Cassandra.InvalidQuery exception with message "No keyspace has been specified" would be thrown and logged.
On a system with Cassandra Cluster and OpenSearch, it is currently not yet possible to export SLAs.
Problem when generating a default MessageBrokerConfig.json file [ID 44155]
When neither an SLCloud.xml file nor a MessageBrokerConfig.json file could not be found on a DataMiner Agent, up to now, any process using MessageBroker would fail to generate a default MessageBrokerConfig.json file. As a result, it would not be possible to connect to NATS.
From now on, when neither a SLCloud.xml file nor a MessageBrokerConfig.json file can be found, a default MessageBrokerConfig.json file will be generated.
Elements hosted on another DMA and under the root view would not be visible if you did not have full access to the root view [ID 44170]
In client applications like DataMiner Cube, up to now, elements hosted on a DMA other than the one you were connected to would incorrectly not be visible in the Surveyor if they were directly under the root view and if you did not have full access to that root view.
Uploading certain protocol versions would cause elements to no longer be able to execute QActions [ID 44172]
After you had uploaded a protocol with a version that was identical to the prefix of the version of a protocol that was already in use (e.g., a new protocol with version 1.0.0.1 versus an existing protocol with version 1.0.0.1_DEV), up to now, elements using the existing protocol (e.g., with version 1.0.0.1_DEV) would incorrectly no longer be able to execute QActions.
Problem with SLElement when loading elements that included matrix parameters [ID 44188]
In some cases, SLElement could stop working when loading elements that included matrix parameters.
Problem when importing a .dmimport package containing elements that use a production version of a connector [ID 44189]
When you imported a .dmimport package containing an element that used a production version of a connector for which a different version was set as production version on the target agent, up to now, the connector version set as production version in the .dmimport package would incorrectly always be set as new production version on the target agent.
From now on, the system will always ask what you want it to do:
  • Make the connector version in the .dmimport package the new production version on the target agent, and allow the imported element to still use the production version.
OR
  • Leave the production version untouched on the target agent, and update the imported element so that it no longer uses the production version but the referenced version instead.
STaaS: Problem when migrating or importing elements with logger tables [ID 44196]
On systems using STaaS, when an element with logger tables had been migrated from one DMA to another, up to now, that element would no longer start up after it was migrated back to its original DMA.
Also, on system using STaaS, up to now, when importing a DELT package containing elements with logger tables, the logger table data would not be imported correctly.
RAD parameter groups would no longer get monitored when a parameter had not had a value for more than 5 days [ID 44204]
When a parameter within a RAD parameter group had not had a value for more than 5 days, up to now, SLAnalytics would incorrectly lose track of the entire parameter group. As a result, no anomalies would get detected for that group, and create, update and delete actions performed on that group would fail.
Problem when retrieving historic alarms with a filter on the value of a discrete parameter [ID 44221]
When historic alarms were retrieved with a filter on the value of a discrete parameter, up to now, no alarms would be returned.
This was due to the parameter value being incorrectly translated to a numeric value.
No retries would incorrectly be attempted when retrieving DMS configuration info failed [ID 44240]
When a client application connects to a DataMiner System, it retrieves the configuration info of that DataMiner System.
Up to now, when retrieving that info failed, no retries would incorrectly be attempted. From now on, a retry will be attempted every 10 seconds.
Problem when trying to create, update, or delete users or user groups [ID 44245]
Because of file locking issues, in some cases, errors could occur when trying to create, update, or delete users or user groups.
Crowd: HTTP response codes would incorrectly be ignored [ID 44254]
When DataMiner was configured to import users and groups from a Crowd server, SLDataMiner would incorrectly disregard HTTP result codes while parsing a response during the hourly LDAP synchronization. This could lead to users being removed from their groups until the next successful synchronization, causing them to be unable to log in to DataMiner.
BrokerGateway: getnatsconnectiondetails calls would slow down whenever an IP address listed in appsettings.runtime.json could not be reached [ID 44287]
Up to now, whenever an IP address listed in BrokerGateway's appsettings.runtime.json file could not be reached, getnatsconnectiondetails calls would slow down for all MessageBroker clients, causing DataMiner to not start up as it would not be able to contact the StorageModule DcM fast enough.
Problem when calling NotifyDataMiner NT_ELEMENT_STARTUP_COMPLETE for an element while that element was being renamed [ID 44288]
When a QAction called NotifyDataMiner NT_ELEMENT_STARTUP_COMPLETE for its own element while that element was being renamed, up to now, a deadlock would occur, causing a runtime error.
Problem with SLDataMiner when a version of a DVE connector was set to production version [ID 44308]
When a version of a DVE connector was set to production version, in some cases, a fatal error could occur in SLDataMiner.
A history set parameter with a constant value would not properly update its new timestamp [ID 44318]
Up to now, a history set parameter with a constant value would not properly update its new timestamp when a set parameter was triggered with a more recent timestamp.
Service impact of exported DVE parameter or DCF interface state of DVE element were incorrect when monitored parameters of the DVE element were polled but not saved [ID 44341]
After a DataMiner restart or an element restart, in some cases, the service impact of an exported parameter or the DCF interface state of a DVE element would be incorrect when the monitored parameters of the DVE element in question were polled but not saved, especially when those monitored parameters were associated with active alarms.
Protocols - PortSettings: DefaultValue and Disabled child elements of SkipCertificateVerification element would not be read if the connection was not the primary connection [ID 44343]
In the <PortSettings> element of an HTTP connection, you can configure a <SkipCertificateVerification> element with child elements <DefaultValue> and <Disabled>. Up to now, both child elements would incorrectly not be read if the connection in question was not the primary connection.
Problem with SLDataMiner when an incomplete JSON response was received from Microsoft Entra ID [ID 44391]
In some cases, a fatal error could occur in SLDataMiner when an incomplete JSON response was received from Microsoft Entra ID while authenticating a user via SAML.
Failing attempt to create an alarm for an element being stopped could block the alarm thread [ID 44394]
When an alarm cannot be created for a particular element, an attempt is made to fetch the element state for logging purposes.
Up to now, in some cases, when the element was being stopped and was flushing its data to the database, this fetch operation could block the alarm thread. As a result, no new alarms would get processed for that element until the element had stopped flushing its data.
Delay of DataMiner startup routine caused by SLDataMiner starting up faster than SLNet [ID 44438]
During DataMiner startup, in some rare cases, SLDataMiner would start up faster than SLNet. This would cause a delay of about 2 minutes in the entire startup routine.
