General Feature Release 10.6.3 CU1
Before you upgrade to this DataMiner version:
Changes
Fixes
SLNet will no longer take into account the log level before sending a log entry to SLLog [ID 44868]
In DataMiner Main Release 10.5.0 CU12, Main Release 10.6.0, and Feature Release 10.6.3, a change was made to make sure SLNet would only send a log entry to SLLog if the log level dictates that the entry should be logged.
This change has now been reverted as it caused SLNet to leak handles whenever a user authenticated using SAML and a new SLHelper process was started.
