General Feature Release 10.6.6
Before you upgrade to this DataMiner version:
Highlights
Swarming can now be enabled for a smart-serial element in server mode [ID 45173]
In a DataMiner protocol, you can now indicate that swarming should be allowed for an element with a smart-serial connection in server mode.
By default, swarming is not allowed for such elements. However, if your element can communicate with its data source at startup to specify where data should be sent, you can now safely enable swarming by adding the following configuration to the protocol.xml file:
<Swarming>
    <BypassChecks>
        <Check>smartSerialAsServer</Check>
    </BypassChecks>
</Swarming>
New features
DataMiner Object Models: DomDefinitionReferences and FieldValueReferences can now be marked as read-only [ID 45275]
When you configure DOM security, you can now set DomDefinitionReferences and FieldValueReferences to read-only. This way, you can give user groups safe, controlled access based on a specific reference, allowing users to see and inspect data but not change it.
To support this, the DOM API now includes a ReadOnly property (of type boolean) in the DomDefinitionReference and FieldValueReference classes.
With Read access, users can:
  • Read the DOM instances
  • Retrieve specific fields from the DOM instances
  • Count the DOM instances
  • Receive the events when subscribed to DOM instance changes
  • Retrieve DOM attachments linked to DOM instances
  • Read the DOM instance history
  • Count the DOM instance history records
With Write access, which is the default behavior when the ReadOnly property is not enabled, users can:
  • Create, update, or delete DOM instances
  • Add or remove DOM attachments on a DOM instance
Support for this feature in the DOM security UI in DataMiner Cube is currently still being implemented. Consequently, it is not yet possible to configure read-only access via that UI, and if changes are made to DOM security via the UI, any read-only flags will be cleared.
Changes
Enhancements
Enhanced performance when retrieving service state information [ID 44392]
Because of a number of enhancements, performance has increased when retrieving service state information.
From now on, a GetServiceStateMessage will no longer be forwarded to the Agent hosting the service. Instead, the service state information will be retrieved from the local SLNet cache.
Connector synchronization enhancements [ID 44715]
A number of enhancements have been made with regard to the synchronization of connectors within a DataMiner System:
  • The first time you upload a version of a new connector, it will automatically be set as production version. Up to now, when a connector version was automatically set as production, this would trigger a synchronization of that version. From now on, the new connector will be synchronized within the cluster, and when a DataMiner Agent detects that it is the first version, it will set it as the production version.
  • Up to now, when a parent connector exported child connectors (as is the case with DVE connectors), these exported child connectors would be synchronized within the cluster when the parent connector was added or modified. From now on, only the parent connector will be synchronized, and each DataMiner Agent will then generate the child connectors.
  • From now on, a protocol.xml file that is generated based on the active function.xml file will no longer be synchronized when the function is activated.
The midnight sync has not been altered.
Enhanced logging for connections towards SLNet [ID 44765] [ID 45359]
A number of improvements have been made to SLNet logging, particularly to help troubleshoot unexpected disconnects between SLNet instances and between SLNet and DataMiner Cube.
New log files
In the C:\Skyline DataMiner\Logging folder, you can now find the following new log files:
Log file Description
SLNetConnections.txt An entry will be added each time an SLNet to SLNet connection encounters a timeout.
SLCubeConnections.txt An entry will be added each time a Cube to SLNet connection encounters a timeout.
If information logging is set to Level 4, the log entries will also mention if a message is waiting until other calls have finished. Up to 10 active calls are allowed at any given time.
Existing log files
  • ConnectionDiagnostics in C:\Skyline DataMiner\Logging\SLNet\ConnectionDiagnostics will now also report which calls were in progress at a certain point in time.
  • SLHangingCalls.txt will now contain more detailed information:
    • Apart from blocking calls, it will now also log asynchronous calls.
    • The entries will now mention the exact message that is hanging, rather than the wrapping EncryptedMessage.
  • Log entries can also be added to SLNetConnections.txt and SLCubeConnections.txt for SLNet connections created elsewhere. To do so, provide a LoggerProvider to SLNetTypesDiagnostics.AddLoggerProvider().
  • When a Cube connected to a system without server-side SLNetTypesDiagnostics connects to a system with server-side SLNetTypesDiagnostics, the SLCubeConnections.txt log file will not be populated. Restart Cube if you want that log file to be populated.
STaaS: Enhanced performance when closing alarm trees [ID 45081]
Because of a number of enhancements, on STaaS systems, overall performance has increased when closing alarm trees.
DataMiner Object Models: SLDataGateway will now try to read only the selected fields from an OpenSearch or Elasticsearch database [ID 45151]
When SLDataGateway is retrieving DOM data from an OpenSearch or Elasticsearch database, from now on, it will attempt to retrieve only the selected fields using the native field projection capabilities of these databases. This will considerably enhance data transfer efficiency and overall performance.
This optimization will leverage the indexed field values to avoid transferring complete objects when only specific fields are needed.
If selected field retrieval is not supported by the database, the system will automatically fall back to retrieving the full object and extracting the required values. This currently applies to STaaS and to queries that require post-filtering or post-sorting.
By default, the value type will be the field type defined by the exposer. When a field value is explicitly requested, the type defined in the field descriptor will be used instead.
To ensure correct type resolution, field descriptor IDs must be unique across all section definitions within a DOM module. Non-unique IDs may result in incorrect type mapping and unexpected behavior.
BrokerGateway installer will now give a clear indication when .NET is missing [ID 45169]
When you install the BrokerGateway DxM on a server that does not have the Microsoft .NET hosting bundle installed yet, from now on, a message will appear, saying that .NET has to be installed first.
Correlation: GetAvailableCorrelationRulesMessage response now also includes grouping information [ID 45187]
When a GetAvailableCorrelationRulesMessage is sent to SLNet, the response will now also include information regarding the grouping defined in the correlation rules.
DataMiner upgrade: .NET Framework 4.8 will no longer be installed [ID 45196]
From now on, during a DataMiner upgrade, Microsoft .NET Framework 4.8 will no longer be installed.
On most machines running DataMiner, this will already be installed. If, for any reason, you need to install this package, it can be downloaded from the official download page.
DataMiner upgrade: A number of default Visio stencils will no longer be included [ID 45202]
From now on, a DataMiner upgrade package will no longer contain the following Visio stencil files:
  • AppearTV DC1000.vss
  • AppearTV DC1100.vss
  • AppearTV MC3000.vss
  • AppearTV MC3100.vss
  • AppearTV SC2000.vss
  • AppearTV SC2100.vss
  • BridgeTech.vss
  • Nimbra300.vss
  • Nimbra600.vss
  • NimbraNodes.vss
  • United States Maps (US units).vss
  • World Maps (Metric).vss
  • World Maps (US units).vss
Note that the following stencil files will still be deployed:
  • Buttons.vssm
  • Icons.vssx
  • KPI.vssm
  • SkylineNewDrawing.vsdx
The above-mentioned stencil files that are no longer included in DataMiner upgrade packages will not automatically be removed from existing systems.
Automation: Compiled assemblies generated during syntax checks will no longer be loaded into memory [ID 45214]
Up to now, when a syntax check was performed on an automation script (e.g., by clicking Validate in a script's C# block in DataMiner Cube), the compiled assembly would be loaded into the SLAutomation memory.
From now on, compiled assemblies generated during syntax checks will no longer be loaded into memory.
SLLogCollector: Only BPA tests deployed by default will be rerun each time a log package is created [ID 45228]
Up to now, each time SLLogCollector created a log package, it would rerun all BPA tests deployed on the system. From now on, it will only rerun the BPA tests deployed by default.
Each time a log package is created, all BPA test results available on the system will still be included in that package. This means that all results from non-default BPA tests will also be included, even when, from now on, these tests are no longer rerun when a package is created.
APIGateway: Enhanced handling of files in use during upgrades [ID 45230]
From now on, the Windows Restart Manager will be enabled during installations. This will prevent unnecessary delays caused by files still in use by the APIGateway instance that is being upgraded, increasing overall performance and reliability of the upgrade process.
Number of smart-serial messages allowed to enter has now been limited [ID 45273]
In order to protect DataMiner against a continuously growing queue of incoming smart-serial messages, the number of smart-serial messages that are allowed to enter per element with smart-serial connections has now been limited.
  • If more than 200 MB of messages are waiting in the queue, a notice alarm will be generated, and a log entry will be added to the SLErrorsInProtocol.txt file. This is meant as a warning. As soon as the queue drops below 150 MB again and the maximum limit is not breached, the notice alarm will be cleared.
  • If more than 300 MB of messages are waiting in the queue, an error alarm will be generated, and a log entry will be added to the SLErrorsInProtocol.txt file. As the maximum limit was breached, the queue will no longer accept any additional messages.
  • Once the maximum limit has been breached, the queue will need to drop below 200 MB before new messages can be added again. As soon as the queue drops below 200 MB, the error alarm will become a notice alarm. Note that, even when the queue would be empty, the notice alarm will not be cleared. It will serve as an indication that part of the communication was lost.
  • We strongly advise you to restart the element when the limit has been breached. When certain messages within a data stream get dropped because the maximum queue limit was breached, an incomplete data stream may get processed, which could then produce unexpected results.
  • The alarm not only mentions the limit that was reached (in MB). It also mentions the number of messages that are present in the queue. This number of messages is not always equal to the number of responses to be processed. For example, in some cases, Windows can combine multiple received UDP packets into one when adding packets to the receive buffer, causing SLPort to then add a single message to the queue.
DxMs upgraded [ID 45304] [ID 45347]
The following DataMiner Extension Modules (DxMs), which are included in the DataMiner upgrade package, have been upgraded to the indicated versions:
  • DataMiner ArtifactDeployer 1.8.8
  • DataMiner CoreGateway 2.14.17
  • DataMiner FieldControl 2.12.1
  • DataMiner Orchestrator 1.8.2
  • DataMiner SupportAssistant 1.9.1
For detailed information about the changes included in those versions, refer to the DxM release notes.
DataMiner upgrade: Clients can now also connect to the orchestrating Agent when it has finished upgrading locally [ID 45312]
When you upgrade an entire DMS, every DMA will upgrade itself locally, and one of them, the so-called orchestrating Agent, will give you progress updates. This orchestrating Agent is the Agent from which the upgrade was triggered.
Up to now, while a full DMS upgrade was in progress, you could connect with a client application (e.g., DataMiner Cube) to any of the Agents that had finished upgrading locally, except the orchestrating Agent. Even when that Agent had finished upgrading locally, it would not be possible to connect to it. From now on, this will be possible.
Aliases can now be configured for DaaS systems [ID 45327]
If you want to configure an alias for a DataMiner Agent, in the DataMiner.xml file, the mode attribute of the DMAName element has to be set to "manual". If this attribute is not set to "manual", configuring an alias will also change the computer name, which will cause unintended behavior.
As it is not possible for a user to make changes to the DataMiner.xml file of a DaaS system, up to now, it would not be possible to configure an alias for such a system. From now on, in the DataMiner.xml file of a DaaS system, the mode attribute of the DMAName element will be set to "manual" by default. This will allow users to also configure aliases for DaaS systems.
SLLogCollector packages now include hosts and lmhosts files [ID 45369]
From now on, SLLogCollector packages will also include the following files:
File Description
C:\Windows\System32\drivers\etc\hosts Maps hostnames to IP addresses for DNS name resolution. Used to override or supplement DNS locally.
C:\Windows\System32\drivers\etc\lmhosts Maps NetBIOS names to IP addresses for legacy Windows networking. Rarely used in modern systems.
Both files will be added to the Network Information folder.
Fixes
BPA tests could incorrectly not be run on DMAs that were not connected to the internet [ID 45040]
Up to now, it would not be possible to run BPA tests on DataMiner Agents that were not connected to the internet because they were not able to fetch the necessary certificates.
From now on, it will be possible to run BPA tests on DataMiner Agents that are not connected to the internet.
STaaS: Problem when retrieving data to be visualized in 'State timeline' components or element and parameter heatlines [ID 45043]
When, on systems using STaaS, the GetReportTimelineDataMessage was used to retrieve data to be visualized in State timeline components or element and parameter heatlines, in some cases, the data that was visualized would not be correct.
Dynamic units: A unit would incorrectly be assigned to date/time parameters [ID 45047]
When the dynamic units feature is enabled in, for example, DataMiner Cube, many numerical values are automatically converted into more readable formats with appropriate units. Up to now, the dynamic units feature would incorrectly also try to assign a unit to parameters of type date/time.
SLLogCollector: Problem when running BPA tests [ID 45053]
When the SLLogCollector tool was configured to execute all BPA tests available in the system when collecting log packages, up to now, in some cases, executing those BPA tests would fail and cause them to report a wide variety of exceptions.
From now on, when the SLLogCollector tool detects that it is not possible to execute the BPA tests, it will skip their execution and collect the results of their last successful run.
Alarm squashing: Alarm would incorrectly not show up in the Alarm Console when the element had been restarted and the AlarmsPerParameter limit was exceeded [ID 45063]
When, on a system with alarm squashing enabled, the AlarmsPerParameter limit in the AlarmSettings section of the MaintenanceSettings.xml file was exceeded, an alarm of which all alarms in the alarm tree were squashable would incorrectly not show up in the Alarm Console after the element associated with the alarm had been restarted.
SLWatchdog incorrectly interpreted processes being stopped during a DataMiner shutdown as a crash [ID 45115]
When DataMiner is shutting down, processes are expected to be stopped. However, up to now, the tracking in SLWatchdog would not be cleaned correctly, causing certain processes to still be monitored. When these processes eventually stopped, SLWatchdog would incorrectly interpret this as a crash, which would then trigger a number of crash detection features, such as notifying CDMR or attempting to perform a full restart.
SLAnalytics: Problem due to a large number of state icon events being added to the SLNet queue simultaneously [ID 45145]
In some cases, timeouts could occur due to a large number of state icon events being added to the SLNet queue simultaneously.
From now on, the number of state icon events sent by SLAnalytics instances will be reduced to a maximum of 10,000 events per minute. Also, they will be sent in batches of maximum 1000 events.
Additionally, state icon events, alarm focus events and RAD parameter aggregation events will now all have a smaller weight, meaning that more of them will be allowed in the queue.
Problem with alarm forwarding after an element had been edited [ID 45167]
When an element had been edited, in some cases, alarm updates would incorrectly no longer be forwarded to northbound SNMP managers.
This fix will not work if the element in question has the Enable SNMP agent option enabled, and has a virtual IP address and a subnet mask configured.
Up to now, during NATS migrations or NATS-related BPA test runs, establishing connections to NATS servers of other DataMiner Agents in the DMS would be slow due to reverse DNS lookups.
SLNet: Problems with user picture requests would cause other messages to get blocked [ID 45210]
When SLNet was not able to respond to user picture requests from a web app, up to now, those requests could stay active within SLNet for several minutes, causing other messages to get blocked.
From now on, user picture requests will time out after 10 seconds.
Problem when a connector was using the makeCommandByProtocol option while in slow poll mode [ID 45217]
Up to now, a problem could occur when a connector was using the makeCommandByProtocol option while in slow poll mode. The slow poll timer triggered the ping pair command as soon as the slow poll group was added to the execution queue. However, this caused a problem when regular groups were still being processed. If a valid response arrived at that moment, the system attempted to stop the slow poll timer. This failed because the timer was waiting for the response to release its resources, which led to an issue.
From now on, the slow poll timer will no longer make the ping command when adding the slow poll group to the queue. The ping command will be made when the group is executed, and the makeCommandByProtocol setting will be disregarded.
SLAnalytics: Problem due to incorrect internal state in Automatic Incident Tracking [ID 45220]
In some cases, SLAnalytics could stop working due to an incorrect internal state in Automatic Incident Tracking.
An alarm will now be generated when a protocol connection acting as a server failed to bind to the socket [ID 45241]
When a protocol connection that acted as a server failed to bind to the socket during startup, up to now, this would only get logged (with debug level 1). From now on, this will be assigned error level 0.
Also, the element will go into an error state, and an alarm indicating a failing binding will be generated.
SLNet: MessageBroker cache could leak NATS threads [ID 45259]
In some rare cases, the MessageBroker cache of SLNet could leak NATS threads.
Service & Resource Management: Problem when the Agent with the lowest DMA ID was removed from a DataMiner System [ID 45281]
Up to now, when the Agent with the lowest DMA ID had been removed from a DataMiner System, the Resource Manager would incorrectly still consider the removed Agent the master DMA and would still attempt to communicate with it. As a result, master synchronization requests would fail, producing errors like the following one:
System.AggregateException: One or more errors occurred. ---> Skyline.DataMiner.Net.Exceptions.DataMinerException: Fatal error while sending request [MasterSyncRequestMessage for message of type SetReservationInstanceMessage from XXX] to master DMA XXX, max retries reached. ---> Skyline.DataMiner.Net.MasterSync.MasterSyncerException: Could not use the connection to master DMA XXX
From now on, when the Agent with the lowest DMA ID was removed from the DataMiner System, the Resource Manager will correctly re-evaluate and update the master DMA when it receives a master synchronization request.
SLDataMiner: Problem when trying to fetch information about loopback adapters [ID 45285]
When the SLDataMiner process starts, it tries to fetch information about all network adapters. However, up to now, when it tried to fetch information about a loopback adapter, an error resembling the following one would be thrown:
CIPSettings::Init|ERR|-1|Opening device failed for adapter {14763620-5D53-11EA-90D5-806E6F6E6963} (Software Loopback Interface 1): The system cannot find the file specified. (2)
As loopback adapters are not part of any communication flow, from now on, SLDataMiner will no longer try to fetch information about those adapters.
Elements incorrectly moved to root view after moving view with service containing those elements to view containing the original elements [ID 45286]
When a view containing a service was moved to another view, it could occur that elements included in that service were incorrectly moved to the root view. This happened when an element was only included in the original view because of the service, but the element already existed in the target view. This behavior has been corrected.
DataMiner upgrade: Incorrect .NET 6 error would be thrown during the upgrade process [ID 45374]
Up to now, the first time a newly installed DataMiner Agent was upgraded, an incorrect .NET 6 error would be thrown during the upgrade process.
SLAutomation could stop working when recompiling libraries [ID 45436]
Up to now, in some cases, SLAutomation could stop working when recompiling libraries.
