Installing the Generic Penalty Box
Deploying the Generic Penalty Box
Deploy the Generic Penalty Box solution from the Catalog.
When the deployment is complete, go to the folder
C:\Skyline DataMiner\Webpages\Public\generic-penalty-boxon the DataMiner Agent.Edit generic-penalty-box/config.json to match your environment (protocol name, parameter IDs, etc.).
For details, see Configuring the Generic Penalty Box.
Browse to
http://[DMA name]/public/generic-penalty-box/in a web browser.
Creating additional penalty boxes
It is possible to display multiple penalty box walls on the same DataMiner Agent, each with its own configuration, for example, one per connector or one per site.
To do this, copy the deployed generic-penalty-box folder in C:\Skyline DataMiner\Webpages\Public and rename the copy, for example to generic-penalty-box-eaton-ups.
You can then configure each copy independently by editing its own config.json, and you can access the copies using the folder name, for example, http://[DMA name]/public/generic-penalty-box-eaton-ups/.
