Installing the Smart Trap Processor tool
Deploying the Smart Trap Processor tool
  1. Look up the Smart Trap Processor package in the Catalog.
  2. Click the Deploy button.
  3. Select the target DataMiner System and confirm the deployment. The package will be pushed to the DataMiner System.
    If this is the first time you install the tool, a new view and element named "Smart Trap Processor" will automatically be created when the package is installed. Optionally, you can rename the element and view, and you can change their location in the Surveyor.
    Once the package has been installed, you can access the Smart Trap Processor low-code app at http(s)://[DMA name]/root.
    Smart Trap Processor app
  • To update the Smart Trap Processor tool, redeploy the Smart Trap Processor package. The tool will be updated, but no new Trap Processor element will be created, as one should already exist in your DMS.
  • When you install the tool, default alarm and trend templates are applied to enable alarm monitoring and trending on the Event State and Heartbeat Status parameters. You can customize these templates, for example if more complex alarm thresholds are required beyond the defaults. See About the alarm template editor.
