Remote PHY Monitoring
The Remote PHY Monitoring Solution allows you to monitor Remote PHY devices. Two low-code apps are included in the solution package. These provide an overview of all nodes and also allow you to monitor more specific information related to particular nodes.
The Remote PHY Monitoring Solution is installed by means of a package in the Catalog. This package contains different components, including the above-mentioned low-code apps.
See also: Remote PHY Monitoring on DataMiner Dojo.
