Installing InfraOps
To install InfraOps:
Confirm whether the following prerequisites are met:
- Your system uses DataMiner 10.5.9/10.6.0 or higher.
- The GQI DxM is installed.
- MediaOps Plan 1.1.3-CU0 or higher is installed.
- Web File Manager is installed.
Look up the InfraOps package in the DataMiner Catalog.
If all prerequisites are met, click the Deploy button.
For more details on deploying items from the Catalog, see Deploying a Catalog item to your system.
During the installation, the following steps will automatically be executed:
- Prerequisites are checked.
- Automation scripts are installed/updated.
- Applications are installed/updated.
- DOM definitions are installed/updated.
- In case of a fresh install, the system is initialized.
- Any required migration actions are executed.
- Any required cleanup actions are executed.
