Adding a DataMiner Probe
From DataMiner version 8.5.4 onwards, you can add DataMiner Probes to a DMS. To do so, follow the same procedure as when you add a DMA in Cube, with one difference:
- In the Add DataMiner Agent pop-up window, select the checkbox Add as an external DataMiner Agent.
Note that given the special nature of DMPs, there are differences compared to regular DataMiner Agents:
DMPs are only displayed in the manage tab of the Agents page. There it is possible to modify the settings or change the state of a DMP, like for any other Agent.
If you click the client communication indicator in the top right corner of the Cube interface, DMPs are not displayed in the list of DMAs in the system.
The client manages the connection to the DMP. If the connection cannot be set initially, you can try to reconnect until a stable connection has been made.
