Adding a regular DataMiner Agent
See also: Agents – Adding a DMA to a cluster
- Before you add a DataMiner Agent, make sure the IP network ports are configured correctly. See Configuring the IP network ports.
- If the DataMiner System uses STaaS, additional steps are required. See Adding a DataMiner Agent to a DMS running STaaS.
On the DMA you intend to add to the cluster, go to the System Center module and select the Agents page.
On the Manage tab, select the DataMiner Agent to which you are connected.
In the pane on the right, next to Cluster, enter the name of the DMS, and then click Add Cluster (prior to DataMiner 10.0.13) or Join cluster (from DataMiner 10.0.13 onwards).
On a DMA that is currently already in the cluster, go to the System Center module and select the Agents page.
In the Manage tab, below the list of DMAs in the cluster, click Add.
Enter the IP address or the hostname of the DMA you want to add and click Add.
To avoid a mix of different environments, enter the IP address instead of the hostname if the DataMiner System already contains a Failover pair configured with virtual IP addresses. From DataMiner 10.2.0 [CU21]/10.3.0 [CU9]/10.3.12 onwards, adding a hostname in such a case will be impossible.
To add a Failover pair to a DataMiner System, first add the primary DMA as a regular DataMiner Agent, and then configure Failover. See Preparing the two DataMiner Agents.
To verify if your DataMiner cluster is working correctly, you can run the Check Cluster SLNet Connections BPA test.
