Installing a DMS Dashboard Gateway
This information is applicable to the DMS Dashboards module, which is being retired as of DataMiner version 10.4.x. See DataMiner functionality evolution and retirement. For more information on the Dashboards web app available from DataMiner 9.6.9 onwards, see Dashboards app.
For a Dashboard Gateway to function correctly, an additional Windows component, Internet Information Services, must also be installed. On some Windows versions this is installed by default, but on others you will need to install it yourself.
Installing a Dashboard Gateway on Windows Server 2012
To install a Dashboard Gateway on Windows Server 2012, you must first install IIS, then install the dashboards, configure IIS, and finally configure the web.config file.
Installing IIS
Go to Start > Server Manager.
On the Dashboard page, click Add roles and features.
In the Add Roles and Features Wizard, click Next to go to the Server Roles step.
On the Server Roles tab, select Web Server (IIS) and Management Tools.
Expand the Application Development node to select ASP.NET 3.5, ASP.NET 4.5, .NET Extensibility 3.5 and .NET Extensibility 4.5.
Click Install to start the installation process.
After the installation, which can take a few minutes, open the start menu and type “iis manager” to open the Internet Information Services (IIS) Manager.
In the navigation menu on the left, select Application Pools.
Right-click the DefaultAppPool and select the item Advanced Settings.
In the Process model section, set the item Idle Time-out (minutes) to 0 and click OK to confirm.
Right-click the DefaultAppPool again and select the item Recycling.
Disable the property Regular time interval (in minutes).
Installing the dashboards
Copy the directory C:\Skyline DataMiner\Webpages\Dashboards from the DataMiner Agent to a location on the DataMiner Gateway, such as C:\Skyline DataMiner.
Remove all the files and subfolders in the directory ...\Dashboards\db.
Configuring IIS
Go to Start > Control Panel > Administrative Tools > Internet Information Services (IIS) Manager.
Click the root (name of the DataMiner Gateway) and select Feature Delegation.
For the items Handler Mappings, Modules, Authentication - Anonymous and Authentication - Windows, change the delegation from Read Only to Read/Write.
In the navigation menu on the left, select COMPUTERNAME > Web Sites > Default Web Site.
Right-click and select Add Virtual Directory.
Fill in the alias, “Example dashboards”, and the correct path to the dashboard folder.
Right-click the new item and select Convert to Application.
Click OK.
Select COMPUTERNAME > Web Sites > Default Web Site > Dashboards in the navigation menu on the left.
In the HTTP Features section of the Feature View tab, double-click the item Mime Types.
To the list of Mime Types, add the Mime Type fcss by right-clicking in the list and selecting Add.
Choose the file name extension fcss and the Mime Type text/plain, and click OK to confirm.
Configuring the web.config file
In DataMiner, create a new user profile with access to all elements in the DMS. The user also has to have the permission Modules > System configuration > Tools > Admin tools. See Adding a user.
This user will be used by the Dashboard Gateway to access the DMA. The username and password of this user will be used in step 4 of this procedure.
On the Dashboard Gateway, open the file web.config with Notepad.
In the file, search for the term appName = "Dashboard".
Change the attributes from the “add” tag from:
<add id="local" connectionstring="localhost" description="Local DataMiner Cluster">
to:
<add id="local" connectionstring="[IP DMA]" user="[name dashboard user]" password="[password of Dashboard user]" description="Dashboard DMA">
Installing a Dashboard Gateway on Vista Server
To install a Dashboard Gateway on Windows Vista Server, you must first install IIS, and then install the dashboards.
Installing IIS
Go to Start > Control Panel > Programs and features.
Click Turn Windows features on or off.
In the feature list, select Internet Information Services.
In the World Wide Web subdirectory Application Development Features, select the following features:
.Net Extensibility
ASP
ASP.NET
ISAPI Extensions
ISAPI Filter
Also under World Wide Web, select the checkbox of the directory Security.
Click OK to start the installation.
After the installation, which can take several minutes, go to Start > Control Panel > Administrative Tools > Internet Information Services (IIS) Manager.
Set the item Idle Time-out (minutes) in the Process model section to 0 and click OK to confirm.
Installing a Dashboard Gateway on Windows Server 2003
To install a Dashboard Gateway on Windows Server 2003, you must first install IIS, then install the dashboards, configure IIS, and finally configure the web.config file.
Windows Server 2003 is not supported from DataMiner 9.0 onwards.
Installing IIS
Go to Start > Control Panel > Add or Remove Programs.
On the right-hand side, click Add/Remove Windows Components.
Enable IIS:
For Windows 2000/XP: select the checkbox for Internet Information Services (IIS).
For Windows 2003:
Select the checkbox for Application Server.
While Application Server is selected, click Details.
Select the checkbox for ASP.NET.
Select Internet Information Services (IIS) and click Details.
Select World Wide Web Service and click Details.
Select the checkbox for Active Server Pages.
Click OK three times to go back to the Windows Components Wizard
In the wizard, click Next to start the installation.
The installation can take several minutes. Depending on the Windows installation, the Windows Installation CD may be required.
Click Finish to close the wizard, and close the Add or Remove Programs window.
After the installation, go to Start > Control Panel > Administrative Tools > Internet Information Services (IIS) Manager.
In the navigation menu on the left, right-click the DefaultAppPool, which is located in the node Application Pools, and select Properties.
On the Recycling tab, disable the property Recycle worker processes (in minutes).
On the Performance page, disable the property Shutdown worker processes after being idle for (time in minutes).
Apply the changes.
Configuring IIS
Select New, Virtual Directory.
Follow the wizard and fill in the alias, “Example dashboards”, and the correct path to the dashboards folder.
Select the following permissions:
Read
Run scripts
Execute
Click Finish.
Right-click Default Web Site and select Properties.
On the HTTP Headers tab, click the item Mime Types.
Click the New button.
Add the extension fcss and select the Mime Type text/plain, then confirm by clicking OK three times.
In the navigation menu on the left, go to COMPUTERNAME > Web Sites > Default Web Site > Dashboards.
Right-click Dashboards and select Properties.
Select the Documents tab page and add the content page Default.aspx.
Configuring the web.config File
In DataMiner, create a new user profile with access to all elements in the DMS. See Adding a user.
to:
