Component overview
This section contains an overview of the Reporter components you can publish on a website:
Alarm distribution graph
A graph showing the alarm distribution in a particular time range.
When an error occurs (e.g. no data available), a redirect to nograph.gif will occur.
Syntax
Alarm distribution graph of an element:
createAlarmDistributionUrl(element, distriType, avgType, width, height, distriTypeParam, view)
Alarm distribution graph of a service:
createServiceAlarmDistributionUrl(service, distriType, avgType, width, height, distriTypeParam, view)
Parameters
Parameter Description
element The name of the element.
Set to ALL_ELEMENTS to view the total distribution for all elements.
service The ID of the service. Format: DmaID/ServiceID
distriType The type of graph. Default: DISTRIBUTION_DAY
- If distriType is set to DISTRIBUTION_GIVEN_WEEKDAY, distriTypeParam can hold a number from 1 to 7 (1 equals Sunday).
- If distriType is set to DISTRIBUTION_GIVEN_MONTHDAY, distriTypeParam has to be set to the day number. The current date decreased with one month will be taken as day number 1. As a result, this is limited to 31 days.
See also: Alarm distribution graph types
avgType The average type.
See also: Time period
width The width of the graph (optional, default: 300 px).
height The height of the graph (optional, default: 220 px).
distriTypeParam The day to be shown if distriType is set to DISTRIBUTION_GIVEN_WEEKDAY or DISTRIBUTION_GIVEN_MONTHDAY.
view The name of view by which to filter the data.
Alarm states vs. alarm count scatter graph
A graph showing a comparison of the different alarm events versus the alarm states.
Syntax
createAlarmScatterUrl(width, height, state, view)
Parameters
state The alarm state filter.
See also: Alarm severities
Alarm states pie graph
A graph showing what percentage of the time an element or a service was in each of the alarm states.
Syntax
Alarm states pie graph for an element:
createAlarmStatesUrl(element, width, height, span)
Alarm states pie graph for a service:
createServiceAlarmStatesUrl(service, width, height, span)
Parameters
span Time span.
Possible values (strings):
- DAY (last 24 hours)
- HOUR (last hour)
- 12HOURS (last 12 hours)
- WEEK (week to date)
- MONTH (month to date)
- PREVMONTH (previous month)
- YESTERDAY (yesterday)
- YEAR (year to date)
Note: When the span argument is omitted or empty, DAY will be used by default.
Alarm states time line
A graph showing a time line with the most severe alarm states of an element or a service during the last 24 hours.
Syntax
Alarm states time line for an element:
createTimelineUrl(element, width, height, span)
Alarm states time line for a service:
createServiceTimelineUrl(service, width, height, span)
Parameters
span Time span.
- HOUR (last hour)
Alarm types pie graph
A graph showing the amount of new alarms of an element or a service, grouped by alarm severity.
Syntax
Alarm types pie graph for an element:
createNewAlarmsUrl(element, width, height, span)
Alarm types pie graph for a service:
createServiceNewAlarmsUrl(service, width, height, span)
Parameters
span Time span.
- HOUR (last hour)
New alarm count graph
A bar graph showing the top X worst elements based on either alarm state or alarm amount.
Syntax
Top X of the worst elements based on alarm state:
createTopStatesUrl(amount, width, height, view, state)
Top X of the worst elements based on alarm amount:
createTopNewUrl(amount, width, height, view, state)
Parameters
amount The maximum number of devices to be displayed in the graph.
Spectrum monitor buffer
The image of the most recent spectrum analyzer trace that was measured by a particular spectrum analyzer monitor script.
Syntax
createSpectrumBufferUrl(element, width, height, monitor, traceId)
Parameters
width The width of the graph (optional, default: 600 px).
height The height of the graph (optional, default: 450 px).
monitor The ID of the spectrum monitor (which is displayed when you edit the monitor).
traceId The ID of the trace.
Format: measurementpointName>traceName (as defined in the monitor script)
Spectrum monitor traces
The image of the spectrum analyzer trace that was measured by a particular spectrum analyzer element at the time the image was requested.
Syntax
createSpectrumRTUrl(element, width, height, measpt, preset)
Parameters
measpt The ID of the measurement point.
- You can find the measurement point IDs in the measurement point configuration window.
- Use -1 when no measurement point needs to be used.
preset The name of the public preset to be used.
Instead, you can also specify an inline preset definition. See Inline preset definition
Example of a generated URL
http://ipAddress/reports/graphs/SpectrumRT.asp?
element=element&
measpt=-1&
preset=inline:freqstart:450000;freqstop:500000000
Syntax:
inline:property1:value1;property2:value2;...
Property names
  • amountPoints
  • detectMode
  • firstMixerInput
  • freqCenter (Hz)
  • freqSpan (Hz)
  • freqStart (Hz)
  • freqStop (Hz)
  • inputAtten
  • preamp
  • scaleType
  • sweep (default: auto)
  • rbw (default: auto)
  • refLevel (default: 0 dBm)
  • refScale (default: 10)
  • vbw (default: auto)
When you specify an inline preset definition, you have to define at least the following properties:
  • freqStart and freqStop, or
  • freqCenter and freqSpan.
Trend graph
A graph showing trending information for a particular parameter.
Syntax
createTrendGraphUrl(element, param, trendType, width, height, showMinMax)
Parameters
param The ID of the parameter.
trendType The type of trend graph. Default: TREND_HOUR
See also: Trend graph types
showMinMax Whether or not the graph has to show minimum and maximum values:
- 1 = Show minimum and maximum
- 0 = Only show average
