Setting up authentication and creating the ASP pages
Do the following if you want to be able to show DataMiner report components on webpages by means of <img> tags:
Copy the
C:\Skyline DataMiner\Webpages\Reports\RemoteGraphs
folder from the DataMiner Agent to an arbitrary location on your web server.On the DataMiner Agent, create a file named
C:\Skyline DataMiner\Reporter.xml
. In it, specify the secret string that will be shared by the DataMiner Agent and the web server as a means of authentication:<Reporter> <RemoteGraphs> <SharedSecret>secret string</SharedSecret> </RemoteGraphs> </Reporter>
On the web server, open the
RemoteGraphs\Config.inc.asp
file and edit the following two lines:strRemoteUrl = 'http://DataMiner Agent IP Address/Reports/Graphs/'; strSharedSecret = 'secret string';
In the RemoteGraphs folder on the web server, create an ASP page for each report graph. Here you see the ASP page for the Alarm Distribution graph (MyAlarmDistribution.asp):
<%@ Language="JScript" %> <!-- #include file="RemoteImages.inc.asp" --> <% var strUrl = createAlarmDistributionUrl( ALL_ELEMENTS, // element DISTRIBUTION_DAY, // distriType TIMEPERIOD_WEEK, // avgType 600, // width 300, // height 0, // distriTypeParam '' // view filter ); getRemoteImage(strUrl); %>
For more information on the create...Url methods you can use in your ASP scripts, see Component overview.
Once your ASP pages have all been created, you can refer to them in any webpage using an <img> tag similar to this one:
<img src="http://webserver/RemoteGraphs/MyAlarmDistribution.asp" width="600" height="300" alt="Alarm Distribution for last day" />
