Sharing DataMiner data with third parties
There are many ways in which you can make your DataMiner System share information (real-time device readings, fault data, performance data, etc.) with third parties.
Sharing app
The Sharing app allows you to share live data via dataminer.services. For more information, see About the Sharing app.
DataMiner Cube
  • Allow the third party to remotely access your DataMiner System through the ports required for DataMiner Cube.
  • Set up and maintain a dedicated user profile for the third party (which devices can be accessed, what kind of actions can be performed, etc.).
DataMiner Monitoring app
  • Allow the third party to remotely access your DataMiner System through the ports required for DataMiner web applications.
  • Use the Monitoring app for mobile access to DataMiner.
DataMiner Dashboard Gateway
  • Set up DataMiner Dashboard Gateway on your internet server.
  • Define and configure the necessary dashboards, which should contain all relevant information that you want to share with the third party.
DataMiner Northbound Interfaces
  • Use the DataMiner NBIs to query DataMiner for the information that you want to share with the third party.
  • Create the client application (e.g., webpage, mobile phone app, etc.) with which you want to share the information with the third party.
  • Not all DataMiner NBIs are available by default. Optional licenses may be required.
DataMiner Replication
  • Set up and maintain a dedicated user profile for the third party.
  • The third party needs to have a separate DataMiner System onto which the elements can be replicated.
See also: Replicated elements
