Customizing the component layout
Each component in a dashboard or low-code app has a number of default options. By default, the configuration of these options is determined by the layout of the dashboard or low-code app on the whole. However, it is possible to override this. The way this can be done depends on the DataMiner version.
  1. Select the component and go to the Layout pane on the right.
  2. In the General section, you can configure basic component information:
    • Title: Enter a custom title that appears in the upper-left corner of the component.
    • Name: Available from DataMiner 10.4.0 [CU18]/10.5.0 [CU6]/10.5.9 onwards. Enter a custom name for the component. Using a custom name can make it easier to identify components when configuring a dashboard or low-code app. When you leave this setting empty, the default name consists of the type of visualization followed by a sequence number (e.g., Table 3).
  3. In the Styles section, you can then change the component theme in different ways:
    • To change the component theme to one of the different existing component themes for your current dashboard or low-code app theme, click the current theme and select a different theme in the dropdown list.
    • To customize the component theme, enable the Customize toggle button to customize the currently selected theme.
      • In the Title section, specify the following:
        • Font: Select a font type in the dropdown list
        • Font size: The size (in pixels) of the title
        • Alignment: Left, center, right, or justify
        You can also further customize your title with Bold, Italics, and Underline.
      • In the Colors section, specify a custom background color and/or font color, either by specifying the color in RGB format, by entering the hex value or HTML color name, or by using the color picker box on the right.
        Under Colors > Accent color (available from DataMiner 10.4.0 [CU12]/10.5.3 onwards), you can specify an accent color. If a component supports an accent color (e.g., the toggle component), it will inherit the selected color. By default, this is set to Default, meaning the accent color will match the theme of the dashboard or low-code app.
        Under Colors > Data colors or Colors > Color palette (prior to DataMiner 10.3.0 [CU16]/10.4.0 [CU4]/10.4.7), you can customize additional component colors, e.g., for the lines in a line chart.
        From DataMiner 10.3.0 [CU16]/10.4.0 [CU4]/10.4.7 onwards, under Colors > Data colors, you can specify conditional colors. If a display label of the data matches the specified text, that data will inherit the conditional color. These conditional colors override the normal data colors.
        To add a conditional color:
        1. Expand the Conditional colors section below Data colors.
        2. Select Add conditional color.
        3. Enter a regular expression to match the display label. For example, entering Tot will match data labeled Total, while entering ^Tot$ will only match data labeled Tot.
        4. Choose a custom color, either by specifying the color in RGB format, by entering the hex value or HTML color name, or by using the color picker box on the right.
      • In the Spacing section, specify the following:
        • Vertical margin: The amount of space (in pixels) above the component.
        • Horizontal margin: The amount of space (in pixels) next to the component.
        • Vertical padding: The amount of space (in pixels) that should be left free at the top of the bottom inside the component.
        • Horizontal padding: The amount of space (in pixels) that should be left free on the left and right side of the component.
        If a smaller value than the dashboard's or low code app's default value is configured for these settings, it will not be taken into account.
      • In the Border section, specify the following:
        • Roundness: The roundness (in pixels) of the border that should be displayed around the components.
        • Style:
          • No border
          • Line
          • Dashes
          • Dots
        • Sides: Select which sides of the component border should be shown.
        • Thickness: The thickness (in pixels) of the border that should be displayed around the components.
        • Color: Specify a custom border color, either by specifying the color in RGB format, by entering the hex value or HTML color name, or by using the color picker box on the right.
      • In the Shadow section, select the size of the shadow displayed behind the components.
      When you have customized a component theme, you can also save it, so that it becomes available with the other component themes for the current dashboard or low-code app theme. To do so, click Save as component theme and specify the name of the theme. However, note that this is only possible if the dashboard or low-code app is currently using a saved theme. If it is not, you will first need to save the dashboard or low-code app theme before you can save the component theme.
