Dashboards and Low-Code Apps
With the Dashboards app and Low-Code Apps module, you can consolidate any data from your monitored system, so you can access it on any device.
Dashboards and low-code apps can be as simple or complex as you want, using components that are configured in the same way across both modules. They are particularly useful for selectively sharing specific data with third parties, without the need to grant access to your entire system.
The main difference between a dashboard and a low-code app is that the latter can combine multiple "dashboards" in one application, with additional functionality: actions can be triggered based on specific events (e.g., a user clicks a button, a page is loaded, a panel is closed, etc.), you can configure panels that can for instance be shown as a pop-up window or an overlay, and you can incorporate menus and submenus into the header bar.
💡 TIPS TO TAKE FLIGHT
More of a visual learner? Watch this short video to see how a new dashboard can be created from scratch, or watch this video to see a low-code app in action.
Skye
