SNMPv1/v2 connections
For SNMPv1/v2 connections, you can specify the following connection settings while creating or editing an element:
SNMP version: Allows you to select a different SNMP version than the version configured in the protocol. With an SNMPv1 type protocol, you can select SNMPv1, SNMPv2 or SNMPv3. With an SNMPv2 type protocol, you can select SNMPv2 or SNMPv3.
Site: The remote location. Set to
<None>if a direct connection needs to be set up instead of a tunnel. This dropdown is only visible if the EdgeManager DxM is installed and remote locations are configured. For more information, refer to Edge Gateways.IP address/host: The polling IP or URL of the destination.
From DataMiner 10.5.9/10.6.0 onwards, you can fill in a hostname instead of an IP address even if the connection will be used to receive SNMP traps. In earlier versions, using a hostname is not supported for SNMP trap reception.
Network: The network interface (NIC). If only one network interface is available on the DMA, it is automatically selected.
Port number: By default 161.
Use credentials: If predefined credentials have been made available for your user account, you can select this checkbox to select a set of predefined SNMP credentials. See also: Credentials Library.
Get community string: The community string used when reading values from the device. The default value, unless overridden in the protocol, is public.
Set community string: The community string used when setting values on the device. The default value, unless overridden in the protocol, is private.
Note that setting an empty set community string is only possible from DataMiner 10.5.0 [CU20]/10.6.0 [CU8]/10.6.11 onwards, and only if the SnmpPollingSnmpPlusPlusOnly soft-launch option is enabled.
