General Feature Release 10.6.8
- For release notes related to DataMiner Cube, see DataMiner Cube Feature Release 10.6.8.
- For release notes related to the DataMiner web applications, see DataMiner web apps Feature Release 10.6.8.
- For information on how to upgrade DataMiner, see Upgrading a DataMiner Agent.
Before you upgrade to this DataMiner version:
Make sure version 14.44.35211.0 or higher of the Microsoft Visual C++ x86/x64 redistributables is installed. Otherwise, the upgrade will trigger an automatic reboot of the DMA in order to complete the installation.
The latest version of the redistributables can be downloaded from the Microsoft website:
Make sure all DataMiner Agents in the cluster have been migrated to the BrokerGateway-managed NATS solution.
For detailed information, see Migrating to BrokerGateway.
Important changes
The following changes may have an impact on your system, so please make sure to check these before you upgrade:
- Correlation: Grouping method 'By alarm' has been removed [ID 45545]
- DataMiner Agents will now translate the primary key to the display key when receiving timeline data requests from a client [ID 45579]
- Dashboards/Low-Code Apps: State timeline component will now use the primary key when requesting timeline data [ID 45600]
New features
User-Defined APIs can now use dynamic route segments to expose path parameters to the trigger script [ID 45681]
From now on, user-defined APIs can use dynamic route segments to expose path parameters to the trigger script.
A route such as items/{id} or a/{x}/b/{y} no longer needs to be fully literal, and the values that appear in the request path are forwarded to the automation script.
A dynamic route segment is written as {parameterName}. The parameter name is captured as-is and becomes available in ApiTriggerInput.RouteParameters within the API trigger automation script. For example, a request to items/42 against the route items/{id} will provide id = 42.
Dynamic route matching
Route matching now distinguishes between static and dynamic routes:
- Static routes continue to work as before.
- Static routes always win over dynamic routes when both match the same request.
- Literal route segments are matched case-insensitively.
- The full number of segments must match. Partial matches are not accepted.
- Dynamic routes are evaluated in specificity order, so that more literal routes win over more generic templates.
That means items/special will match the static route items/special before the dynamic route items/{id}, and, in case of foo/bar, foo/{bar} will win over {foo}/bar because the first literal segment is more specific.
Route parameters
When a dynamic route matches, the captured path values are passed through to the script as a dictionary of route parameters.
Route parameters:
- Are exposed on
ApiTriggerInput.RouteParameters. - Use the parameter name from the template as the key.
- Preserve the exact incoming path segment as the value.
- Are empty for static route matches.
Route validation and conflicts
Routes are validated more strictly before create and update:
- A route cannot be null, empty, or whitespace only.
- A route cannot start or end with
/. - A route cannot contain empty path segments.
- A parameter segment must be written as a well-formed
{name}placeholder. - Parameter names cannot use route syntax characters such as
/,{,},?,*,:, or=. - A route template cannot reuse the same parameter name more than once within the same route.
Route conflicts are also detected across all existing definitions. Any two templates that can match the same request path are rejected, including conflicts between literal and parameterized routes and between overlapping parameterized templates. If a route with ticket/{id} already exists, a new route like ticket/{ticketId} will be rejected.
When a conflict is found, the API definition is rejected with ApiDefinitionError.Reason.RouteInUse, and the error includes both the conflicting definition ID and the route that was rejected.
Changes
Breaking changes
When a client requests timeline data using a GetReportTimeLineDataMessage, it sends the primary key when referencing display column tables. However, for this type of table, the DataMiner Agent has to retrieve the data from the database using the display key.
From now on, when a DataMiner Agent receives a timeline data request, it will first translate the primary key to the display key before returning the requested data.
Enhancements
Exception.Source field will now be added to ErrorLog.txt when a managed process stops unexpectedly [ID 44722]
When a managed process stops unexpectedly, from now on, the contents of the exception's Source field will now be added to the ErrorLog.txt log file. This should provide more debug information.
DataMiner Object Models: SLDataGateway will now try to read only the selected fields from a STaaS database [ID 45503]
When SLDataGateway is retrieving DOM data from a STaaS database, from now on, it will attempt to retrieve only the selected fields using the native field projection capabilities of these databases. This will considerably enhance data transfer efficiency and overall performance.
This optimization will leverage the indexed field values to avoid transferring complete objects when only specific fields are needed.
If selected field retrieval is not supported by the database, the system will automatically fall back to retrieving the full object and extracting the required values.
By default, the value type will be the field type defined by the exposer. When a field value is explicitly requested, the type defined in the field descriptor will be used instead.
To ensure correct type resolution, field descriptor IDs must be unique across all section definitions within a DOM module. Non-unique IDs may result in incorrect type mapping and unexpected behavior.
Database migration from Cassandra Cluster to STaaS is now allowed on systems with Swarming enabled [ID 45507]
From now on, it is possible to migrate the database of a Swarming-enabled system from Cassandra Cluster to STaaS.
- This migration will be a snapshot migration, not a live migration.
- Migrating the database will only be possible if the system is online, cloud-connected, and has an active Cassandra Cluster database.
Visual Overview in web apps: Problem when creating a new window [ID 45517]
Because of the way Cube sessions are loaded in the SLHelper process when creating visual overviews, up to now, Windows could throw an exception creating a new window. This would cause the SLHelper process to crash, affecting all active Cube sessions.
From now on, the system will attempt to recreate the Cube session when the initial creation fails, and will handle any failures gracefully to ensure other sessions remain unaffected.
GQI will now throw an exception when data is requested from a mediated table parameter [ID 45539]
Currently, because of server limitations, GQI is unable to retrieve parameter table data from DataMiner when that table is a mediated parameter. As a result, when you select a table of a mediated protocol in a client UI, that table will not contain any data, and will also not provide any details on why it does not do so.
From now on, when a query using the Parameters for elements where data source attempts to retrieve data from a mediated table parameter, GQI will throw an error. That error will indicate that the request is not valid because mediated tables are not supported, and will also mention the table or table columns involved.
User-Defined APIs can now also be triggered by sending a PATCH request method [ID 45542]
To trigger a user-defined API, up to now, you had to send a GET, PUT, POST, or DELETE request method to the UserDefinableApiEndpoint DxM.
From now on, it will also be possible to trigger a user-defined API by sending a PATCH request method.
SLManagedScripting: AssemblyLoad event handler will also log the location of the loaded assembly [ID 45547]
From now on, the AssemblyLoad event handler in SLManagedScripting will also log the location of the loaded assembly (if available).
Automation: Script library hint paths will only be sent to the script compilation engine the first time they are required [ID 45560]
Previously, when a script library was added to a DataMiner System, its hint paths were automatically sent to the automation script compilation engine, even when the library was not used by any automation script.
From now on, script library hint paths will only be sent to the automation script compilation engine the first time they are required, i.e., when a script referencing the library in question (either directly or via another library) is executed for the first time.
SLElementInProtocol.txt log file entries will now be added by SLLog instead of SLProtocol [ID 45578]
Up to now, the SLElementInProtocol.txt log file entries were added by SLProtocol.
From now on, these log file entries will be added by SLLog instead.
SLLogCollector will now retrieve the value of the Windows security policy 'System cryptography: Use FIPS compliant algorithms for encryption, hashing, and signing' is enabled [ID 45592]
From now on, SLLogCollector will also retrieve the value of the Windows security policy System cryptography: Use FIPS compliant algorithms for encryption, hashing, and signing.
DataMiner does not support having this policy enabled. Having this option enabled will prevent DataMiner from starting up properly.
SLNetClientTest tool: Enum field dropdown boxes in 'Build Message' tab will now be sorted alphabetically [ID 45610]
Up to now, each enum field dropdown box in the Build Message tab would show the enum values in the order in which they are defined in the enum.
In order to make it easier to look up values when, for example, building a message, from now on, the enum field dropdown boxes in the Build Message tab will show the enum values in alphabetical order.
Caution
'Check Time Server' BPA test has now been merged with the 'DataMiner Agent Minimum Requirements' BPA test [ID 45631]
In order to combine all system requirements specified in DataMiner Compute Requirements, the Check Time Server BPA test has now been merged with the DataMiner Agent Minimum Requirements BPA test.
From now on, the DataMiner Agent Minimum Requirements BPA test will be executed only once across the entire DataMiner System. The test results from the individual Agents in the cluster will be aggregated.
SLAutomation: Enhanced startup after a DataMiner restart or upgrade [ID 45651]
Up to now, after a DataMiner restart or upgrade, in some cases, SLAutomation could unexpectedly stop working while initializing internal components.
A number of enhancements have now been made to prevent any initialization issues during SLAutomation startup.
BPA test 'Cube CRL Freeze': Enhanced performance [ID 45712]
Because of a number of enhancements, overall performance of the Cube CRL Freeze BPA test has increased.
This BPA test will identify client machines and DataMiner Agents without internet access where the DataMiner Cube application experiences a significant freeze during startup. This freeze is caused by the system attempting to verify the application's digital signatures with online Certificate Revocation Lists (CRLs).
Fixes
Cassandra Cluster / STaaS: 'Alarm events' graph on 'Reports' page of service card would incorrectly be empty [ID 45533]
When, in a DataMiner Cube connected to a DataMiner System using Cassandra Cluster or STaaS, you opened the Reports page of a service card, the Alarm events graph would incorrectly be empty, showing "Alarm data not found in the current time range".
SLWatchDog: Problem when restarting DataMiner after SLDataMiner had stopped working [ID 45543]
When SLDataMiner had stopped working, up to now, any attempt made by SLWatchdog to restart the DataMiner Agent would fail.
From now on, when SLDataMiner or any other critical DataMiner process stops working, SLWatchdog will be able to correctly restart the DataMiner Agent.
SLNet/SLDataGateway: Paging requests via SLNetInternalRepository could fail when the paging cookie expired mid-session [ID 45550]
In some cases, paged retrievals of DOM instances or booking instances could fail with an InvalidOperationException when the server-side paging cookie expired before all pages were fetched. In GQI-powered low-code apps, this could then surface as a random error:
Select failed, could not read the objects from the database: System.InvalidOperationException: The provided cookie was not found among the live paging handlers of this storage type. Maybe it has already been deleted.
From now on, SLDataGateway will gracefully reset an expired paging cookie instead of throwing an error. When the cookie is no longer found among the live paging handlers, a fresh paging session will automatically be started.
Also, SelectPagingHelper will now maintain a set of all object IDs received across pages. When a paging session restarts due to a cookie renewal, previously returned objects are filtered out, preventing duplicates from being returned.
AssemblyResolveHelper now returns already loaded fallback assembly if it was already loaded [ID 45567]
When the AssemblyResolveHelper in SLCompilationEngine cannot find the exact version of the assembly it has to load, by default, it will try to load an assembly with the same name but a different version.
Up to now, when the assembly with the different version was already loaded in the application domain, the AssemblyResolveHelper would incorrectly return null.
From now on, when the assembly with the different version is already loaded in the application domain, the AssemblyResolveHelper will again correctly return the already loaded assembly.
Failover: Advanced Failover options could incorrectly not be changed when BrokerGateway was being used [ID 45613]
Up to now, when a Failover setup was using BrokerGateway, it would incorrectly not be possible to change any of the advanced Failover options.
SLWatchDog: Log entry describing a process restart would incorrectly not include the names of the restarted processes [ID 45614]
When SLWatchDog had queued a process restart after having detected that one or more non-critical processes had stop working, up to now, the associated log entry would incorrectly not include the names of the affected processes: Queueing Process Restarts in 1 minute ()
From now on, this log entry will correctly include the names of the processes being restarted. For example: Queueing Process Restarts in 1 minute (SLProtocol.exe)
NATSRepair.exe would incorrectly no longer work on new DMAs installed using DataMiner Installer v10.6 [ID 45636]
The NATSRepair.exe tool would incorrectly no longer work on new DataMiner Agents that had been installed using a DataMiner Installer v10.6.
Problem when logging in to a DaaS system using external authentication [ID 45637]
Up to now, when you logged in to a DaaS system using external authentication, in some cases, the DaaS system would incorrectly not be flagged as such. As a result, you would be allowed to access functionality that is restricted to non-DaaS systems.
MessageBroker would not be able to connect to the NATS bus of a DMA when the server name of the DMA was an invalid DNS name [ID 45640]
Up to now, MessageBroker would not be able to connect to the NATS bus of a DataMiner Agent when the server name of that Agent was an invalid DNS name.
From now on, NATSRepair.exe and NATSMigration.exe will now make sure the default MessageBrokerConfig.json file points to localhost instead of the server name.
SLASPConnection could stop working when it failed to retrieve the local IP address [ID 45656]
In some cases, the SLASPConnection process could stop working when it failed to retrieve the local IP address.
Problem when forwarding SNMPv3 traps [ID 45660]
When, within a DataMiner System, a DataMiner Agent receives an SNMPv3 trap for an element hosted by another DataMiner Agent, it will forward that trap to the other Agent. However, in some cases, when the Agent that received the trap did not have the correct credentials needed to decrypt the trap, it would fail to forward the trap to the element.
APIGateway: Problem with reverse proxy feature [ID 45688]
The reverse proxy feature in APIGateway would no longer work.
Whenever a DxM registered itself for reverse proxying, APIGateway could throw an exception.
Problem when synchronizing files in the C:\Skyline DataMiner\Webpages\Public folder [ID 45694]
Up to now, it would no longer be possible to synchronize any files in the C:\Skyline DataMiner\Webpages\Public folder among DataMiner Agents in a cluster because the path name would incorrectly be compared case sensitively.
