General Feature Release 10.6.9 CU1
- For release notes related to DataMiner Cube, see DataMiner Cube Feature Release 10.6.9.
- For release notes related to the DataMiner web applications, see DataMiner web apps Feature Release 10.6.9.
- For information on how to upgrade DataMiner, see Upgrading a DataMiner Agent.
Before you upgrade to this DataMiner version:
Make sure version 14.44.35211.0 or higher of the Microsoft Visual C++ x86/x64 redistributables is installed. Otherwise, the upgrade will trigger an automatic reboot of the DMA in order to complete the installation.
The latest version of the redistributables can be downloaded from the Microsoft website:
Make sure all DataMiner Agents in the cluster have been migrated to the BrokerGateway-managed NATS solution.
For detailed information, see Migrating to BrokerGateway.
Changes
Enhancements
Security enhancements [ID 46368] [ID 46411] [ID 46510] [ID 46515]
