Installing the Ping Monitoring tool
Deploying the Ping Monitoring tool
  1. Look up the Generic Ping package in the Catalog.
  2. Click the Deploy button.
  3. Select the target DataMiner System and confirm the deployment. The package will then be pushed to the DataMiner System.
  4. Go to http(s)://[DMA name]/root and select PING Monitor to start using the application.
