Restoring a DMA using the DataMiner Taskbar Utility
  1. Make sure the DMA is prepared for the restoration. See Preparing the destination server for a DMA restoration.
  2. In the Windows taskbar, right-click the DataMiner Taskbar Utility icon and click Maintenance > Restore.
  3. In the restore window, click the ... button to select a backup package.
    A description of the contents of the package will appear under Description.
  4. Click Restore to start restoring the DMA.
    In the restore window, the different steps of the restoration process will be displayed.
  5. When the restoration is complete, click Finished.
If a DMA is connected to dataminer.services and you restore it on a new (virtual) server, additional configuration is needed. See Maintaining the dataminer.services connection when restoring a DMA.
To also restore the database, additional steps are needed, depending on your setup:
If you are using Storage as a Service, there is no need to restore the database. If you want to restore your DataMiner Agent on a new (virtual) machine, contact support@dataminer.services to make sure your new setup is connected correctly.
