Adding a DataMiner Agent to a DMS running STaaS
To add a DataMiner Agent to a DMS running STaaS:
  1. Make sure that the DMA you are adding is a clean DMA, meaning that it is a newly installed DMA or a DMA that has been fully reset.
  2. Install the DataMiner Cloud Pack on the new DMA.
  3. Stop DataMiner and CloudGateway on the new DMA.
  4. From a DMA in the cluster where CloudGateway is running, copy the folder C:\ProgramData\Skyline Communications\DataMiner CloudGateway\Data\CcaGatewayPersisted and place it in the same location on the new DMA.
  5. Remove the following files from the folder you just copied to the new DMA:
    • DmsAccessToken.data
    • DmsAccessTokenExpiration.data
    • DmsRefreshToken.data
    • DmsRefreshTokenExpiration.data
  6. Start CloudGateway on the new DMA.
  7. Configure DB.xml to use STaaS:
    1. In the C:\Skyline DataMiner folder, open DB.xml.
    2. Configure the Database tag with type="CloudStorage" as illustrated below:
      <?xml version="1.0"?>
      <DataBases xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns="http://www.skyline.be/config/db">
         <DataBase active="true" local="true" search="true" cloud="true" type="CloudStorage"/>
      </DataBases>
  8. Start DataMiner on the new DMA.
  9. Join the DMA to the cluster using the steps described under Adding a regular DataMiner Agent or Failover configuration in Cube for a Failover Agent.
The DMA should now be connected to the DMS running STaaS.
