Adding C# code to an Automation script
Adding C# code to a script in Cube
To add C# code to a script:
  1. In DataMiner Cube, go to Apps > Automation.
  2. In the Automation module, select the script to which you want to add C# code.
  3. In the Add Action selection box, select C# Code.
  4. In the field mentioning Enter code here, enter the C# code.
  5. Click the downward arrow next to Advanced to configure any of the following settings:
    • Namespace references: Allows you to provide namespace references.
      • This is only applicable in case the script block only contains the lines of code to execute (i.e. it does not make use of classes/methods). In case the C# block does make use of classes/methods, the using statement can be provided in the C# block itself.
      • The following using statements are added by default:
        • using System
        • using System.IO
        • using Skyline.DataMiner.Automation
        • using Skyline.DataMiner.Net
        • using Skyline.DataMiner.Net.Exceptions
        • using Skyline.DataMiner.Net.Messages
        • using Skyline.DataMiner.Net.AutomationUI
    • DLL references: Allows you to reference DLLs that are required by the Automation script.
      The following DLLs are referenced by default:
      • System.dll
      • System.Core.dll
      • System.Xml.dll
      • netstandard.dll (from DataMiner 10.1.11 onwards)
      • SLManagedAutomation.dll
      • SLNetTypes.dll
      • Skyline.DataMiner.Storage.Types.dll
      • SLLoggerUtil.dll
      • SLAnalyticsTypes.dll (from DataMiner 10.1.11 onwards)
      To reference additional DLLs, e.g. a custom DLL placed in the C:\Skyline DataMiner\ProtocolScripts folder, you need to specify an absolute path.
    • Script references: Allows you to refer to other C# blocks. See Compiling a C# code block as a library.
DataMiner uses the .NET Compiler Platform SDK (version 2.9) to validate and compile C# scripts, allowing the use of C# syntax up to and including version 7.3.
Engine object
You can interact with the Automation Engine by interacting with an instance of the Engine class.
When you type engine. in the code editor, you will be presented with a drop-down list of all statements available in the Automation Engine.
By default, C# code used in an Automation script throws an exception when it encounters an undefined or an empty parameter. However, if you add the following line in an Automation script action of type C# code, null will be returned instead.
Example:
engine.SetFlag(RunTimeFlags.AllowUndef);
You can also make sure no exception is thrown when an undefined or empty parameter is encountered in C# code by selecting the general option C#: Return NULL instead of an exception upon a GetParameter of a non-initialized parameter. See General script configuration.
Script class
  • For small Automation scripts, you can enter the logic to be executed without wrapping your code in a class and method.
    Example:
    engine.GenerateInformation("Hello");
    In the example above, DataMiner will create a class Script with a static method Run, where the provided content in the C# code field will form the body of this Run method:
    using System;
    using System.IO;
    using Skyline.DataMiner.Net;
    using Skyline.DataMiner.Net.Exceptions;
    using Skyline.DataMiner.Net.AutomationUI;
    // Other using statements as defined in the Namespace references field.
    public class Script
     public static void Run(Engine engine) {
    DataMiner will only perform this wrapping if it does not detect the string "class Script" in the code you provided.
  • Alternatively, you can provide a class "Script" containing a "Run" method yourself in the C# code field.
    Example:
    public class Script
    • If this approach is used, the provided content in the Namespace references field will be disregarded. Instead, provide the using statements in the C# block itself.
    • If a C# block contains a class called Script within a namespace, that class will be used to launch the script.
      namespace MyNamespace
         public class Script
    • Custom entry points are possible. See Custom entry points.
    Be careful how you handle async code in an Automation script. See Handling async code.
Preprocessor directives
DataMiner compiles C# blocks of Automation scripts with the following preprocessor directives:
  • DCFv1
  • DBInfo
  • ALARM_SQUASHING
    In C# blocks, all code related to alarm squashing (i.e. the combination of consecutive alarm events without a severity change into a single consolidated event) should be enclosed as follows, to allow protocols that contain alarm squashing functionality to also be compiled on DataMiner versions that do not support alarm squashing:
    #if ALARM_SQUASHING
    // Code specific for alarm squashing (DataMiner 10.1.0 and later)
    #else
    // Code for DataMiner 10.0.0 and earlier
    #endif
Script timeout
To prevent problems caused by faulty script statements, every C# code block has a default timeout delay of 10 minutes. If the execution of a C# code block takes longer than 10 minutes, it is aborted.
Inside a code block, you can change the timeout delay for that particular code block by setting the Timeout property of the engine object.
Example:
engine.Timeout = TimeSpan.FromMinutes(30);
Custom entry points
It is possible to define custom entry points for an Automation script. To do so, provide the method you want to use as entry point with the attribute AutomationEntryPointAttribute and specify the type of the entry point. For a regular Automation script entry point, specify AutomationEntryPointType.Types.Default:
[AutomationEntryPoint(AutomationEntryPointType.Types.Default)]
public void Default(IEngine engine)
 engine.GenerateInformation("Default");
The method must match the following delegate type:
public delegate void Default(IEngine engine);
For testing purposes, you can use the AutomationEntryPointTest type:
[AutomationEntryPoint(AutomationEntryPointType.Types.AutomationEntryPointTest)]
public void AutomationEntryPointTest(Engine engine, string testMessage, List<int> testIntList)
 engine.GenerateInformation("AutomationEntryPointTest: " + testMessage + " " + string.Join("", "", testIntList.ToArray()));
Methods annotated with the test type attribute must match the following delegate type:
public delegate void AutomationEntryPointTest(IEngine engine, string testMessage, List<int> testIntList);
  • The entry points must be public. They may be static or non-static.
  • The method names and parameter names can be chosen at will.
  • Cube does not support custom entry points. As such, to execute an Automation script from Cube, you need a Script class with a Run method. Custom entry points can be used when executing an Automation script using the ExecuteScriptMessage class.
Restrictions:
  • An Automation script using custom entry points can have only one executable action, which must be a C# code block.
  • If, in a C# code block, you have defined multiple entry points, you must make sure they are of different types. Multiple entry points of the same type are not allowed.
  • For reasons of backward compatibility, we recommend using the Script class as the entry point class for a script.
  • The script must contain the string "class Script" as otherwise DataMiner will wrap the code. See Script class.
From DataMiner 10.5.7/10.6.0 onwards, the OnRequestScriptInfo entry point allows other Automation scripts (or any other code) to request information about the script in question. Information about implementing that entry point and executing it is available in this how-to.
Online help and user assistance
Sample snippets in shortcut menu
When you right-click in the code editor, a shortcut menu will appear. From the Sample Snippets submenu, you can select a number of C# sample snippets.
These snippets will prove helpful when learning how to use C# code in DataMiner Automation scripts, and will also provide a way to quickly add frequently used code.
Syntax check
To verify the syntax of the C# code you entered in the code editor:
  • Below the editor field, click Validate.
    If errors are found, these are enumerated in a field next to the Validate field. Click this field to quickly navigate to the errors in the code block.
IntelliSense
The code editor features IntelliSense. When you type “engine.”, for example, you will get a list of all functions available for this object. You can then just scroll through the list and select the appropriate function by pressing TAB.
Once you have selected a function, type an opening round bracket. You will see all information on what to pass to that function and how.
IntelliSense is available for the following variables:
Entity Example(s)
engine engine.
dummy dummy.
dummyXXX dummy1.
element element.
elementXXX element1.
Note: For elements. or elementsXXX., no IntelliSense is available.
el el.
elXXX el1.
Note: For ele. or eleXXX., no IntelliSense is available.
EmailOptions EmailOptions.
group group.
groupXXX group1.
mem mem.
memXXX mem1.
param param.
paramXXX param1.
subscript subscript.
subscriptXXX subscript1.
report report.
reportXXX report1.
filter filter.
filterXXX filter1.
preset preset.
presetXXX preset1.
service service.
serviceXXX service1.
uib uib.
uibXXX uib1.
uir uir.
uirXXX uir1.
