Creating a dashboard with a dynamic list layout
This information is applicable to the DMS Dashboards module, which is being retired as of DataMiner version 10.4.x. See DataMiner functionality evolution and retirement. For more information on the Dashboards web app available from DataMiner 9.6.9 onwards, see Dashboards app.
If you configure a dashboard to have a dynamic list layout, the components added to the List Item Template zone will be repeated.
To create a dashboard with dynamic list layout:
Go to Actions > Feeds to access the Feeds editor.
Create or select a feed in the Dynamic List Feed field. For more information, see Feeds.
Go to Actions > Settings to set the Dynamic List Options:
Under List Type, specify whether the list has to iterate over dynamic table rows, elements, parameters, redundancy groups or services. Different options will be available depending on your choice. See List type options.
Specify a Minimal Alarm Level to include only items that have at least the specified alarm state.
Use the Mask field to specify a mask to filter the displayed items. E.g. only elements that start with MAIN_*
You can also use regular expressions in the mask field, if the mask starts with #.
In the Appearance drop-down list, you can select different options to display grid lines or an alternating background color.
Enter a value under Rows Per Page to limit the maximum number of rows displayed on one page to that value.
Enter a value under Row Grouping to group multiple rows into one single row. This can be of use when rows are relatively small.
Go to Actions > Configure Components to add components. All components added to the List Item Template zone are immediately configured to use the Dynamic List Feed you configured earlier. For more information about adding components, see Configure Components.
List type options
Depending on the list type you choose when configuring the Dynamic List Options, there are different configuration options.
Dynamic Table Rows
When you choose this list type, each row in the dynamic list will represent a row of a dynamic table.
A dynamic list feed must be configured with “Parameter” as fixed selection, with a dynamic table parameter selected. The display key has to be empty. Components added to the “Dynamic List” layout of the dashboard will only be able to link to a column parameter of the selected dynamic table.
- You can use the Mask option on the Settings page to limit the included parameters to part of a table.
- Unless the list is paginated, new rows will automatically appear in the dashboard when new rows are added to the table.
Elements
When you choose this list type, each row in the dynamic list will represent an element that corresponds to the dynamic list feed.
The following options can be configured for this list type:
Active Elements Only: if selected, only active elements will be included
Spectrum Elements Only: if selected, only spectrum elements will be included
Business Intelligence Only: if selected, only SLA elements will be included
Parameters
When you choose this list type, each row in the dynamic list will represent a parameter that corresponds to the dynamic list feed. Dynamic table parameters are included in the list.
Monitored Parameters Only: if selected, only monitored parameters will be included
Analog Parameters Only: if selected, only analog parameters will be included
Discreet Parameters Only: if selected, only discreet parameters will be included
Average Trended Parameters Only: if selected, only parameters with average trending enabled will be included
Redundancy groups
When you choose this list type, each row in the dynamic list will represent a redundancy group that corresponds to the dynamic list feed. There are no additional options specific to this list type.
Services
When you choose this list type, each row in the dynamic list will represent a service that corresponds to the dynamic list feed.
Select the option Measurement Point Services Only to include only measurement point services.
