Facility Manager
With the Facility Manager application, you can create a hierarchical view of your infrastructure. In this overview, you can define and manage buildings, floors, rooms, zones, rows, desks, and racks.
Facility Manager Overview
App Overview
  • Overview Overview: Provides quick insight in facilities, rack units, and power consumption.
  • Facilities Facilities: Allows you to manage the facilities in your infrastructure.
  • Rooms Rooms: Allows you to manage the available rooms.
  • Racks Racks: Allows you to manage the available racks.
  • Room Designer Room Designer: Allows you to design a room in detail, including the placement of different racks and zones.
  • About About: Provides information about the version of the app and allows you to configure the Google Maps API Key used for the maps displayed in the app.
