DataMiner Low-Code Apps
With the DataMiner Low-Code Apps module, you can create custom applications that interact with data from a DataMiner System or from an external source.
The DataMiner Low-Code Apps module is fully available from DataMiner 10.2.5/10.3.0 onwards. Prior to this, you can preview it if the Applications soft-launch option is enabled.
You can access the Low-Code Apps module via the DataMiner landing page. The apps created in the module can also be accessed from the Apps pane in DataMiner Cube (from DataMiner 10.2.9/10.3.0 onwards).
Low-Code App example
Low-Code Apps module in DataMiner 10.4.9
The Low-Code Apps module requires the "Low-Code Apps" license. For more information on acquiring this license, contact the Skyline Sales department.
  • Along with the other DataMiner web apps, you can upgrade DataMiner Low-Code Apps separately from your main DataMiner installation. This means that you can for example have a DataMiner System using version 10.3.4, while you already use version 10.3.5 for the web apps. You can download the web apps upgrade package from DataMiner Dojo.
  • To view, add, edit, delete, or publish low-code applications, you need to have the necessary user permissions under Modules > User-definable apps as well as the DataMiner web apps user permission.
