Editing a low-code application
You can begin editing a low-code app from within the app or from the DataMiner landing page. If you want to edit a draft app, make sure the draft applications are shown: click the cogwheel button on the landing page and activate Show draft applications.
From the DataMiner landing page (supported from DataMiner 10.3.0 [CU10]/10.4.0 onwards):
Hover the mouse pointer over the app icon until you see the ellipsis ("...") button.
Click the ellipsis button and select Edit.
From within an application:
From DataMiner 10.3.0 [CU18]/10.4.0 [CU6]/10.4.9 onwards, click the pencil icon in the top-right corner.
Prior to DataMiner 10.3.0 [CU18]/10.4.0 [CU6]/10.4.9, click the user icon in the top-right corner and select Edit.
Once you are in edit mode, you can customize the app, or edit the pages, panels, header bar, events, or security as needed.
When the app is ready, click the icon in the header bar to save your changes and publish it.
Once an app has been published, it is not possible to revert it to a draft.
- To view, add, edit, delete, or publish low-code applications, you need to have the necessary user permissions under Modules > User-definable apps as well as the DataMiner web apps user permission.
- It is not possible to edit a low-code app on a mobile device.
See also: Tutorials - Editing an existing app
